AMX In-Ceiling Wi-Fi Antenna
Impaqt
Who has used these? I have some projects coming up where placing a few of these in the ceiling is stategic locations would be a great idea.... If it works....
What kind of Range have you gotten?
Where are you placing the actual ACcess Point? I'd like to put all the AP's int he basement for service and just run RG-??? to the antennas.
Never done it this way. Did it several times with wireless microphones and that works great but at a distance of let's say 20 feet between receiver and antenna. You should use RG-58 cable that's for sure. Be aware that the wap are diversity receivers so i don't know what the impact is of putting the antenna's to far from the wap. You could give it a try in a test case. Maybe you should think about some amplifing between cable and WAP.
Good luck
