NX3200 Crashing Java / Duet error hs_err_pid1279.txt
Hey
I have a NX3200 that keeps crashing and creates a file "hs_err_pid1279.txt" or "hs_err_pid1289.txt"
any ideas whats causing this?
Cheers
Cheers
Simply inserting a blank SD card will not work - it must have the same files as a clean/working NX3200. I strongly suggest you contact technical support to see if they have updated guidance since the original post in 2017.
I've not done it recently, but a few years back, we found that swapping or creating a new clone SD card in an NIx100 altered the NI serial number. Just in case that matters to any licensed software you use! (TP Control site license, CineTouch, likely some others.)
