DVX switching for noobs
robin89
Hi guys!
I'm very new to programming, mostly installing and commissioning systems. Have been given some old gear to use at home including a DVX 3250HD and a MT1002 TP.
I'm trying to switch DVX sources between hdmi input 5, 6, 7, all to hdmi output 1.
I've tried a couple different ways of programming this but I can't get it working so far.
See below an example trying to use TP button 3 to switch input 5 to output 1, I'm converting these numbers to ascii, correct?
Anyone who can see what I'm doing wrong here?
dvTP = 10001:1:0 // MT1002
dvSwitcher = 5002:1:0 // DVX Switcher
button_event[dvTP, 3]
push:
send_string dvSwitcher,"'CL0I53O49T'"
Ok I found my mistake by looking into some old code that was using a DVX.
Following fixed it:
send_command dvDVX, "'CLVIDEOI', itoa(nDVXinput), 'O', itoa(nDVXoutput)"
It seems like I needed to add VIDEO after CL in stead of 0, also use send_command in stead of send_string. Different than what I saw in the netlinx online tutorials. Would this be DVX specific? Anyway this issue is solved
CLVIDEO... will only switch the video level. CLAUDIO... the Audio. If you want switch both, use CLALL...
Short commands are VI... AI... CI...
