Why Am I loosing my IP connection
I am running an NXI-200o with the latest firmware updates. Every time I try to log on via Netlinx Studio it times out. If I reboot the controller (cycling power) I have no problem connecting. When I attempt to listen in Studio under Master Communications the lsiten mode sees the processor. What am I doing wrong or what settings do I need to range.
Connect to the master through the RS232 program port, go to diagnostics, to Network Addresses, and select "Get IP Information". Then set the IP address and Subnet Mask as appropriate, hit "set ip information" and reboot.
AT this point, you will be able to connect to your master _IF_
1. you have the correct physical connection. If you are connecting directly from your PC to the master, you will need a crossover cable -- neither the master nor the NIC card (as far as I know) will work correctly with a cable of the wrong termination type. If you are using a switch/router, make sure that the master and NIC are both connected to LAN terminals and not to an "uplink" or WAN connection. If you are using a switch, you can probably use either straight or crossover cables as most of these devices (DLink, NetGear, Linksys) will automatically accomodate themselves. Best, though, to verify your cable integrity and use only straight cables with switches and crossovers for direct connections and switch to switch connections.
2. Your NIC connection on your PC must be properly configured with an IP address and subnet mask that is appropriate -- that is, your PC and Netlinx master have to be on the same subnet. If your master, for example, is 192.168.1.99 with 255.255.255.0, then your PC must be 192.168.1.n with 255.255.255.0. If one of them is 192.168.1.n and the other is 192.168.0.n, you are likely to be in trouble. Make sure that if your NIC is expecting DHCP that your DHCP server is giving you an IP address to your computer that will work with your master. If you want to see exactly how your NIC card is configured (IP-wise) bring up a "DOS" window (hold down the funny windows key and hit the r key, type in "cmd" where it says "OPEN" and hit <cr> and type in "ipconfig/all" You will get a list of all your IP configurations (duh).
You may need to change settings for your NIC in your "Network Connections" dialog depending on whether or not you have a DHCP server in the network.
Go to control panel, select network connections, right click the NIC (probably listed as LAN) and select properties, select "internet protocol" and select properties and there you are.
I hope this helps and I apologize if I'm covering stuff you already understand.
Harold
If you are already using a static IP, or that doesn't improve anything, look to the code running on the master. If it gets sufficiently bogged down in the message queue, it can fall offline. This could be caused by other network devices going offline, or by too-frequent feedback updates.
Just a thought.
Sheldon Samuels
IPS Resources LLC
