What might I be doing wrong that would cause the DUET web server interface to die?
Joe Hebert
in AMX Hardware
I?m running the latest DUET firmware (v3.11.323) on an NI-700 and some programs that I load cause the web server not to respond. I can?t figure out what these programs have in common other than they are larger size programs (approx.700K-800K .tkn files.) These programs are straight Netlinx with no DUET modules. The programs operate just fine and I can FTP in and Telnet in without any problems at all but the web server just plain refuses to respond.
What I should be seeing is shown in the attached good picture. However, when I first hit the web server after a reboot, I get a crippled interface as shown in the attached bad picture. The interface is incomplete and the links are dead. If I close the browser and then try to hit the web server again, the web server doesn?t respond at all.
When I Telnet in to view the log I don?t see anything out of the ordinary and when I do a show mem it looks like I have plenty of volatile and non volatile memory available. The diagnostics window doesn?t log any problems as far as I can tell either.
Has anyone ever run across this before? Does anyone have any ideas what I might be doing wrong that causes the web server not to respond even though the code runs fine and I can FTP and Telnet in?
TIA
TIA
Don't you love those tech notes? What (who) prompted you to look?
Ricardo
