G3 panel refresh
VLCNCRZR
in AMX Hardware
I am currently working with a G3 series AXT-CG10 color touch panel.
My issue is that sometimes the panel (on its own decision) does a full page
panel refresh when I send a command for activating only a popup page.
Other times, the panel activates the popup like it should, without the annoying full-page refresh.
My background design is somewhat graphically intense, and all of my popups are in a single group. The page processing and commands work fine.
Maybe there is a memory issue or something going on. My popups are over 50%
of the screen image also.
Is there a published limit or threshold that the panel uses to determine if it will just process the popup graphic, or the popup along with the page refresh?
Any ideas?
If only the client would spring for a G4!!!!
Any ideas?
Never mind....I read your post and saw that you have your pop-ups in a group...blows my theory...
It seems that the video window portion of the popup is the primary
culprit for my issue. I removed the window, and everything works
100% of the time.
I scanned through software history and found this issue listed for some other
panels of this family, but it was supposedly rectified with updated firmware.
I believe I have the most current firmware version on this panel.
Although the AMX web site lists firmware for this series (AXT-CA/CV/CG),
firmware transfer does not recognize the listed files as proper files for this panel.
The FG number is different just enough that it wont fly.
I may have to call Tech Support to get the correct file.
Thanks for the responses.
