VPN-CP firmware & setup
Would someone please explain what does label "Wave-Pak (Not) Locked" mean in protected setup? I have a VPN-CP 2-way panel that cannot connect to Netwave server and the only(? - at least now) difference I see is the button with label "Wave-Pak Not Locked"...
Another question if anyone like to clarify: which firmware is newer:
5.03c, 5.03e or 5.03p?
I am a bit confused with numbering there...
And finally - is that correct I need to use SOFTROM program to update firmware on Viewpoint or there is another way?
Thank you in advance,
Maxim
Maxim
And while I'm not sure how it isn't obvious, yes - 5.03p is the latest.
And yes, you need to use SoftRom. Even if this is one of the options in Studio, I've been told to stay away from doing Studio firmware updates on Axlink devices...
This only seems to be an issue when the WAP is real close to the Wave server, but these days Wi-Fi is so prevalent, I can't imagine it isn't going to become an increasingly bigger problem. On a recent project, I was able to pick up no less than 11 nearby access points from a customer's living room, and these were single-family houses. The customer had complained to me he was no longer able to connect to his "upstairs" access point (there was only one in the house, and the location I settled on was an upstairs closet that was central to the house). After trying to talk him through it a bit, I realized he wasn't refering to the location of the WAP, but an SSID of "upstairs." The problem was, that wan't his SSID, it was a neighbor's
For some reason (must have done something really nasty for this punishment), I have found myself working on a large number of old AXCess systems (Axcent2's & Axcent3's wth various panel types including Viewpoints), and have had no issues updating firmware through Studio - and there was a lot of updating.
Viewpoint firmware update through Studio wirelessly..? It is easier than connecting wires and run softrom but I heard it could be dangerous (flash corrupting)... BTW, any clarifications from AMX?
I just downloaded the most current firmware to a VPN-CP panel via NetLinx and my panel has crashed. It now has a continual beep and is not recognized by NetLinx or the SoftROM program. What do I do now? Thanks.
If you are unable to get SoftROM to recognise it, it means firmware flash is corrupted and panel is not able to boot at all, so only way is to get it back to AMX for repair out of warranty !!
Vinc
