Home AMX User Forum AMXForums Archive Threads AMX Website/Forums
Forum CODE: window size
It would be nice if you guys could have the window that displays the code:
Code here xxxx
sized to fit available width of the PC's we're using. It's small and annoying and should be the size of the QUOTE window:
Quote here xxx
I would hazard to say that most of us here are using displays sized 17" and larger and the little CODE window and the scrolling bars is just rediculous!
IMHO.
    I've never worked with vBulletin, but other forum software I have messed with required you to make a simple template edit for this kind of change. Ideally, if the forum software allows it, they should be a percentage of the screen width, but that might be asking too much; if all the wrappers are fixed, you would have to edit every single template to accomodate a variable inclusion, and that's a hecka lot of work. However, it should be really simple just to make the text box values the same for these two styles.
