NI 3000 upgrade issue
Darkside
in AMX Hardware
Hi all,
I have just upgraded an NI 3000 to 3.21.343 and I now have an issue with webcontrol.
It appears to still run the goahead server - which I thought was ditched with the duet firmware.
Regardless of goahead or not, most screens look a bit like the attachment and I can't see any real reason why...
If anyone has any input, I would appreciate it.
Thanks!
Thanks!
I have an NXI on the same network, and FF2 and IE7 can both get to webcontrol.asp - although the NXI is not DUET based
Or in simple words:
1) download v3 firmware, transfer fails after 3 of 4 parts
2) manually reboot the master
3) reload v3 firmware again, reboot is done automatically
4) enjoy the new webserver
The version that was in the NI was 3.12.332.
When I first did it (v2 to v3), the upgrade was successful - ie no errors reported, and nor did it fail.
As a matter of course, I sent the firmware again this morning, and it is exactly the same.
Clean appears to have solved it...I now have the very fancy new webserver running!
...just got to rebuild all of my g3 panels now!
Thanks for the tip
Spoke too soon perhaps!
I saw the new web interface on the system, and 5 minutes later I got the response as shown in the attached image.
Has anyone seen this error before?
(The SB&A modero is the name of the MVP8400 in the system)
Sequence of events.
Originally there were 3 G3 web panels, 1 program loaded.
Tried the f/w upgrade - no go.
Issued CLEAN DISK which killed the G3s and whatever else, but the program remained I noticed.
D/l the f/w again and as per my recent post, saw the new webserver.
5 minutes later, the err as per the jpg.
IE reports:
The XML page cannot be displayed
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
A semi colon character was expected. Error processing resource 'http://192.168.1.250/web/root/webControl.xml'. Line 8, Pos...
<name>SB&A Modero</name>
See tech note 766.
News to all....
It appears that if you have an ampersand in your G4 webcontrol name, you will bring the webserver to its knees as per the image attached previously.
For testing purposes I have removed the ampersand from the name and the webserver runs properly, but after I put it back, the webserver errors as per the images posted
I always code in a routine that actually tests the mem allocation and then updates it to *normally* 8 mb if not already at that size..
Thanks.
** Since your post, I believe I have nailed it - be interested in any tests you might be able to do to confirm my findings...**
http://www.amxforums.com/showthread.php?t=2059
Post your findings and I'd be happy to help if I can.
This appears to be it.
Be interested to what happens if you had a moment to try it...
