Vista Support?
jjames
Well, as a programmer that loves betas, I decided to try out some AMX software on the Windows Vista Beta 2. I'm happy to report the essential AMX software installed well . . . for the most part. I haven't done extensive testing of the software on Vista, but have done some.
Here's a list of programs that installed fine:
* DIP Switch
* G4 Panel Preview
* NetLinx Studio 2
* Software History
* TPDesign 4
Programs that had some trouble:
* IR Edit v1.3.79.0 - had to install in XP Compatability mode
I'll be installing most (if not all) AMX software on the Vista computer and will report back with more information. Hopefully AMX is working on 100% Vista compatible software, and maybe even coincide a release of NetLinx Studio 3 with Vista's release, which I hope would have a lot of useful features (perhaps can be discussed in another thread.)
Is anyone else using Vista and installed AMX software on it? Luckily NLS2 was compatible as I had to use it for a job when my other computer's battery decided to die . . . I guess it was my fault as I didn't bring the power cord - OOPS!!
* DIP Switch
* G4 Panel Preview
* NetLinx Studio 2
* Software History
* TPDesign 4
I wouldn't bank on it. I remember for quite a long time after the release of XP (as much as a year I think), AMX was saying that they only supported Windows 98. I was extremely annoyed with it. I don't plan on switching to Vista anything like right away, and I really hope I am just being unduly pessimistic, but I can't play around with it either. I'm not switching over until I am absolutely positive it won't bite me in the butt.
Vince
I was wondering if anyone else had these problems, I am able to upload using my XP computer, so its not a connection issue.
Use Vista at your own risk and don't expect any support until it has been offically blessed.
Well, I guess it could also be ironic because it's the first thing in the morning and my brain hasn't defrosted yet
Speaking of alternatives, has anyone had any experience running the AMX software on a Mac?
TKN
Yep for sure if you use an old PPC based Mac you have Virtual PC that works well. If you are on new Intel Mac, you can use Parallels and it works great and efficiently
Vinc
We've all been running Vista since Beta.... All AMX apps run except the USB AMXLAN driver. So no USB transfers until then. All difficulties usually point to driver related problems, e.g. no transfers could be a NIC driver incompatibility issue. Sound drivers are usually incorrect. I usually find that these driver issues are usually easily sorted out by changing to generic drivers or different drivers by the same manufacturer etc. I second the second for Linux AMX apps - and I'm not even a Linux expert!
That's probably doable, actually, making an iPhone applet that can control an AMX. I'll have to try to talk my boss into getting me one so I can justify working on such a thing ... sadly, it's not likely.
I'm not a novice at this either - I worked at AMX in their programming department for around 4 years and I have worked as an independent developer for over 10 years so I have written more systems that most people have ever seen. In my current capacity I have a couple of people working for me as graphic designers that do nothing but develop touch panel pages. They do not write code and they do not have a netlinx system to use. Without using G4 Panel Preview in Vista they are forced to go to an old machine that they had planned to get rid of and use it because it has XP on it so they can run the panel preview. It's a pain the the *** especially if the people are travelling and only have their laptop that has Vista on it.
Back to the question - it seems that people have used panel preview with Vista - my question is HOW ? When I tried to install it on Vista the installation closed and exited on me before it was even installed.
I recently purchased a new laptop that came with Vista.
When ever I download a panel file TP4 will say that some font in the panel is not recognized and will convert to the default font.
Is there a way to stop this from happening? I have unstalled TP4 several times and can't seem to get all the fonts to be recognized.
I use VISTA Ultimate 64.
All AMX program is good working.
I have only problem the VisualArchitecht.
This program is use MSDN SQL. I install SQL 2005 EXPERT.
This is good working, but VA install is not work.
I try VA 1.1 , VA 1,2 and VA 1,3 version...
VA 1,3 is possible work together with SQL 2005 Expert. But the install is not finish the installation..
Error: Device Database has not been properly installed; version 1.3.50. is required.
(Panel Preview install is easy... only need select Windows XP compatible mode)
Same program is not good working with vista...
One way: use XP compatible mode.
How can use:
Select the program file, and click preporities.
Select XP compatible mode.
(I use this and example the AMX G4 PanelPreview program is good work. 100%!)
Only need check the all fonts. (old XP system)
Install manualy the fontsto Vista! AMX...
I use this, and work.
1. I deleted VA and the SQL 2005 Express using control panel.
2. I deleted all of the files and folders from both applications that were left on my drive after the uninstall.
3. I downloaded the SQL 2005 Express (free) from the Microsoft web site (save mode not run mode).
4. Installed SQL 2005 Express.
5. Installed VA. Since SQL was already installed, it did not try a reinstall, but just created the VA database.
I try this. But not work.
AMX SQL server is starting but not filling up all data...
I thing problem is the VISTA 64 bit version...
I'm trying to install Netlinx and TPD4 on a Windows Vista system, and while I realize it's certainly not ideal to do so, it's what I've got at the moment. The problem is, when I go to install AMX software which attempts to install a font mid-process, it hangs up and stops responding at that point. I called AMX Tech Support, and the gentlemen said that people have found ways around the problem, but he couldn't tell me how it was done, as it put a level of liability on AMX at that point.
So I'm asking you, please give me some suggestions on how to bypass this ridiculousness. I've tried changing the compatibility of the install file to Windows XP SP2, but that made no difference. Help!
Thanks!
~Jason
Did you try running the Setup executable as Administrator? I know that has caused trouble for me in the past with Vista. Sometimes the setup program will try to install something where Vista doesn't think it should be allowed so it hangs. I have NS2 and TPD4 on one of my laptops with Vista.
--John
I am proud to report that this actually solved a great deal of problems occurring on the machine. I'm really beginning to wonder if many of the "incompatability" issues in Vista comes as a result of "old" programs not playing nice with the new UAC feature...
Just thought I'd share the work around.
