Bad Axcent3, any suggestions?
Joe
Okay, here's a strange one...I'm updating an old residential system that has an Axcent3 and a 1-way Viewpoint. The owner purchased 3 new TVs for the headwall above his bigscreen. The original integrator had stacked IR devices, leaving me to rebuild an IR library file so I could incorporate the new TV commands. After loading and testing, I could not get any IR commands above channel 60 working from code, but I could actuate them through IREdit. I decided to try and recapture the offending codes and redownload them to the master. The first device took, the second 2 gave me the error 'Failed to Clear Memory'. Multiple attempts to download resulted in the same message, so I pulled the master, removed the batteries for a few minutes and put everything back together. I got the solid 'No Program' light on the Axlink, which I expected.
I tried reloading the .TKO file, but it wouldn't communicate. I opened terminal and where you would normally see the '>', it said 'Axcent 3 0.20 >' I typed 'Help' and what appeared was not the standard help menu. I didn't write it down, but it had stuff mentioning bytes to type to transfer at 38k and 115k and about 3 or 4 more commands. The standard terminal commands didn't work, so I tried reloading the firmware.
It connected and froze at '133k Transferred'. I tried this a few times, same result.
Did I kill it? Can it be brought back, or should I start looking at eBay?
Thanks!
Joe
Thanks!
Joe
Did you try to reload firmware ? so long you don't destroy boot firmware you should be able to reload firmware in it
Vince
