Transfer From G4 Panel
TurnipTruck
Greetings,
I am having limited success transferring from G4 panels back to my office. Sometime they come through, often they result in a Transfer Abort with a NAK and a timeout error. Any suggestions?
Thanks.
Thanks.
-> Are u with latest version of TPDesign4 ?
-> Are Moderos you want to upload from in latest version also for firwmare ?
-> Does transfer abort as soon as beginning or does it start to transfer and then abort ?
-> Are you doing transfer through Ethernet or USB ?
-> Modero is connected through ICSP or Ethernet to NetLinx Master ?
Vinc
-Latest TPD4
-Latest NXD-CV10 firmware
-Aborts well into the tranfer, close to end
-Transferring remotely via Ethernet
-Panel to master connection is Ethernet
There is a CV5 and a CV7 on the system that have uploaded successfully.
Thanks.
It seems logical as for most transfer systems you get a timeout for whole transfer, it was pretty short for G3 panels, it's longer for G4 but you still have one. So if you are unable to do the whole transfer in given time it gives up So you should upgrade the DSL link
Vince
