Thermostats?
TrikinCurt
Anyone have a favorite thermostat for AMX? The only ones I have worked with are Aprilaire. Curious what else is out there. AprilAire is fine but would like one that stores programming on the thermostat and is just controlled/updated by AMX as opposed to relying on it fully.
I know Vantage showed some new ones but I can't find any info on them (not shipping yet, I know that much).
Curt
Curt
Depending on the number of stats and the other requirements on the job, it might fit the bill even with having to add on an Omni controller.
I would really like to offer a programmable thermostat that I can monitor and allow basic controls from the AMX touch panel.
The two options I have come up with are the HAI thermostat and the Proliphix IP thermostats.
The HAI look kind of cheap, but allow scheduled programming from the front panel. They communicate over a 232 bus and the protocol looks pretty good and not too tough, but the thermostat does not initiate messages so you must keep polling for data.
http://www.worthingtonsolutions.com/Manuals/HAI/M01044%20HAI%20Omnistat%20Serial%20Protocol%20r4-98C.pdf
The Proliphix Thermostats have a very nice LCD screen and look good overall, but they require the homeowner to setup the schedule and program the thermostat from their computer, not from the thermostat directly.
The IP protocol looks like everything I need can be done with basic HTTP: command lines and responses. The protocol looks easy for these as well.
http://www.proliphix.com/files/PDP_API_R1_8.pdf
The question:
Has anyone used either of these thermostats enough to comment on their integration and reliability? Oh yeah, I guess I should also ask how they work as thermostats (why people care about that part I don't know).
Thanks for the thoughts.
-Pete
In-Focus Systems, Minneapolis MN
I am curious what you were referring to with the comment about how the HAI thermostats interpret the temperature because I think these could be very viable, inexpensive thermostats to use with AMX.
If you were referring the fact that the temperature is converted to a digit 0-255 (Omni Format), I don't think that is a big issue. It can be fixed with some simple math.
i.e.
Current Temp in Celsius = (0.5 * Omnitemp)-40
Current Temp in Fahrenheit = 32 + (1.8 * (0.5 * OmniTemp - 40))
I just checked the manual for the VST and it shows that can be controlled locally; isn't that right?
Yes, the VST's are a typical normal T-Stat but you can only set the temperature not run a set back program which is what I believe TrikinCurt was reffering to.
These stats are 100 times better than anything else on the market. They are commercial grade units with nearly every feature required by by residential hvac contractors. I can't speak for the commercial side because we no longer do those projects. We have written a module for the tstats that works great. These things are very stable sitting on a network, they don't drop off 422 setups like the April Aires. Scheduling is done very easily via THE BUILT IN WEB INTERFACE AND ALSO REMOTELY THRU THEIR ADMIN SITE. sorry bout the caps...
Schedules should be set and forget anyways otherwise the client should just manually set temps via a tp interface and forget scheduling.
I'm assuming that you are referring to the Proliphix. Is that right?
