Hunter Douglas blinds?
dmurray14dmurray14 Junior MemberPosts: 80
Hey guys,
Anyone hooked up Hunter Douglas motorized blinds to AMX? Looking for a cheaper type solution for motorized blinds.
Dan
  • jjamesjjames Just another dude Posts: 2,906
    We've used them before. This is the IR that we've used with them, and it work fine.
  • dmurray14dmurray14 Junior Member Posts: 80
    Thanks Jeremiah - which ones did you use?
    To be honest - I don't know. I'd have to ask our installer to see if he remembers. Sorry.
    No problem, thanks for the file though!
  • bwestlakebwestlake Junior Member Posts: 82
    DC reversing circuit
    We have controlled both the IR and switched blinds. The switched units use a DC motor (2 wire) and you just reverse the current for UP or DOWN. There is a limit switch built into the blind at each end that is adjustable. We build a little 3-relay circuit to control the blinds. I don't like the IR controlled blinds. I can send you a circuit diagram for the reversing relays if you would like.
  • GSLogicGSLogic Original Member Posts: 562
    Do you control the IR blinds (PowerRise) with relays? If so, I'd like to see how you do that.
