Setting Animation Direction for Bargraphs
Alright, so I'm creating a volume popup, and as we all know volume is boring without the delightful visual aid of a bargraph. So I made my button, turned it to a bargraph, and set the off and on states. So far so good, but the buttons a bit too tall for the dock, so I quickly import the same graphics, just thirty pixels shorter. I switch the state from the taller to the shorter graphics, then lo and behold, it suddenly wants the vertical graph to have the zero value at the top... Why? I haven't a clue, there's literally no difference between the two sets of graphics aside from the fact that one is shorter than the other. I can't find anything to switch this either
-- this seems like there ought to be a simple solution, but I'm simply not finding it. Please help so clients can find their volume both engaging and exciting -- the life of the party, gentlemen.
Thanks!
Thanks!
Also, do you have any ideas as to why it'd be switching between the two graphic sets to begin with? I'm truly befuddled.
Thanks!
