NI700 losing communication
I have NI700 , MVP8400 and CV5 in system, connected over US Robotics switch.
After some hours working, I cannot access NI700 from NetLinx, and I cannot ping master.
When I reboot it (plug out power), it works fine for a while.
Do any one have solution, or source of the problem?
  • SensivaSensiva Posts: 211
    - Check your code.. may be you made the processor to enter an endless loop, this can be done by disabling program run from the dip switch on its back.
    - May be another device started to use the same IP
    - Check memory status... may be it ran out of memory
  • VladaPUBVladaPUB Posts: 139
    FROM TERMINAL
    >url list
        The following URLs exist in the URL connection list
        Entry 0-192.168.9.30:1319 IP=192.168.9.30 State=Looking up IP
      ->Entry 1-192.168.9.35:1319 IP=192.168.9.35 State=Issue Connect
    >show mem
    Volatile Free   : 23388632 (largest free block in bytes)
    NonVolatile Free:   522420 (bytes free)
    Disk Free       : 10471424 (bytes of free space)
    >disk free
    The disk has 10471424 bytes of free space.
  • KimKim Posts: 52
    VladaPUB wrote:
    FROM TERMINAL
    >url list
    >show mem
    >disk free
    If you Ni 700 does not answer on ping how you have got in telnet? If nevertheless the controller answers on ping, but you cannot come on http, what version master firmware in yours unit? If the old version I advise to update, or to use set duet memory look tech note 766
    Do you know to whom are these IPs belong?
    VladaPUB wrote:
    FROM TERMINAL
    >url list
    >show mem
    >disk free
    If one of those IPs belong to you NI-700 then you need to remove it from the URL list or it will cause the problem you are describing.
    If that's all the equipment you have then why is there anything in the URL list?
  • I had NI-3100 network port go out last week. Just another possiblilty to think of. Replace your NI-700 with another NI-700 loaded with same code. This will tell you if it is hardware or not.
    How to remove it from url list ?
    Ni700 have IP 192.168.9.30 witch is in URL list. Other device is PhilipsPronto remote controler.
  • Netlinx Studio Menu Bar under Diagnostic > URL Listing > Remove All
    You don't need nothing in this list unless you connect multiple Netlinx controllers together
