Pioneer PDPLX608 serial protocol
Darkside
We are having a bad time trying to get info from Pioneer for this device.
If anyone has any reference material for the PDPLX608 I would really appreciate it.
I also understand it is the same protocol for any plasma with an '8' at the end of its part number.
Thanks!
Thanks!
Have you got the hardware? Have you tried the normal Pioneer Command set?
INP //INPUT Report Current Input Status
INP + S01 //INPUT 1 Select INPUT1
Spaced exactly like this. No mention of any stx etx bytes.
Really poor documentation - it does look like it has come from the techs in Japan I must say.
This kit is meant to be on the wall and running by Monday!
PM me if you want the .xls
Like the attached file:
The room already has audio, so we simply need power on/off, and source control. Aspect etc. will never change.
...even a couple of cmds posted here or PM'd for that lot will get me through with less pain.
Thanks!
Thanks again,
I spent a full day testing Pioneer's protocol and have come up with a very solid include file. I can't post the file, but I will share this very helpful hint: whenever it responds with the "echo" of a power on or off command, it's ready for the input. If you send a power on command while it's still on, you receive "XXX"; same thing with the power off I believe. This helps when dealing with the power on dead time. If you get the timing right, you have the input command sent and accepted before any image appears on the screen - so it looks like it powers up to the desired input and not switching.
Anyway, I've been dealing with this protocol for a solid 3 three years now, and it ranks right up there with Integra protocol: I just love it!!
Your very welcome! Glad it made your life a little easier!!
There was a Pioneer badged 60 which was actually an NEC Chassis, available after Pioneer purchased an NEC factory I believe. There have certainly been a couple of varients of the Pioneer Protocol, but usually as jjames says it's a pleasure to work with...
