I need to emulate the TP with "real size"
2Fast
I need to emulate or print the panel project in your real scale. The Panel Preview has some options on tab "View" ... but when I change the option nothing happens.
Thanks!
Thanks!
When you say "real scale", that is relative.
I believe the Panel Preview tool displays the panels in the actual
pixel size that the panel project is using.
Depending on the output resolution setting on your PC, this could display
on you monitor much smaller or larger than the actual touch panel.
I would suggest copy and paste the pages to another document, and then experiment
with the pasted size when printing the pages.
I'll try!
Thanks again.
Then a PrtSc will get you your image for export. (Since you cant do that in TPD4!...another of my little beefs!!)
HTH
