Question about compare strings
ondrovicondrovic Junior MemberPosts: 217
is there a way to compare multiple strings?
If(char => Compare_String(char1,Char2) && var <= Compare_String(char3,char4)
    do something
Else
   do something
I guess what i am saying is if char is between char1 & char 2 do something if no do something else
Or is there a better way
    Never mind!
    Your example is kind of confusing and inconsistent with your question, so I'll just answer your question.
    I'd compare the strings with the typical comparison operators < > == <>. Compare_String seems useless unless you want to use the ? wildcard, in which case it would be helpful. Highlight compare_string in your code and hit F1 for details.
    What you want is
    If((char >= char1 && char <= char2) || (char >= char2 && char <= char1)) // I'm not going to assume char1<char2
        //do something (in between)
    Else
       //do something (not in between)
    I haven't actually tried to do this in NetLinx but it should work. If it doesn't then TYPE_CAST all these chars to INTEGER and it will definitely work.
  • ondrovicondrovic Junior Member Posts: 217
    mpullin wrote: »
    What you want is
    Else
    Thanks Matt I will give that a try
    so here is what I have but it doesn't seem to be working correctly
    If((sWeather.Time > sWeather.Sunset) && (sWeather.Time < sWeather.Sunrise))
    	    sWeather.Icon = "sWork,'n.png'"
    	Else
    	    sWeather.Icon = "sWork,'d.png'"
    sWeather.Time = 8:45 PM
    sWeather.Sunset = 8:34 PM
    Any ideas why the file isn't updating correctly?
    If your going to do < or > comparisons of time I would make a function that first converts time to seconds based on 24 hour time. Then just compare the interger values or long values. Or you could do seperate atoi(hour) and atoi(minutes) comparisons.
  • AMXJeffAMXJeff Senior Member Posts: 450
    vining wrote: »
    Actually > and < work just fine this way. No need to do anything else. I do agree the time should be adjusted to 24 hour time.
    IF (TIME > '01:00:00' and TIME < '13:00:00')
    Ya know, that would never had occurred to me that the decimal or binary equivent of ascii time would be sequentally greater too. I don't think I could do it that way though since the concept hurts my brain but maybe in time I can adapt and think more like a programmer who views everything as numbers.
    vining wrote: »
    That's been an old programmers trick for some time. It just so happens that using a comparison like this is actually comparing the hex ascii value of the character which happens to work.
    Somehow, I still don't like to do it. My main code always contains a little routine that converts the current time into decimal integer (seconds of the day. ex: 10,800= 3:00 AM)
    I also convert the calendar day to Julian. It just makes creating and managing anything that schedules a lot more reliable and far fewer logic statements.
    vining wrote: »
    One should note, the reason this works is because the format returned by TIME has leading zeros. Otherwise, 2:00:00 > 11:00:00, etc.
