Training section - Firefox - heads up
mpullin
In Firefox 2, clicking on the "Enter AMX University" link on the training page will not take you into the AMX University system, instead it takes you to a blue learnflex login page where you cannot do anything, not even with your correct AMX.com username/password. There is no workaround, a different browser must be used to access the section (I used IE6).
This issue has been reported.
I did IE7 without a problem. Now, a whole plethora of malware is invading my computer everytime I hit the goodle site. But that's a different story...
Works fine here.... FF 2.0.0.14, Javascript enabled, Cookies enabled
One issue I found that directly relates to this site is if you try and click an attachment it fails and will not open.
It reports:
The image “http://www.amxforums.com/attachment.php?attachmentid=908&d=1214790317” cannot be displayed, because it contains errors.
Weird. Any picture, any time
Sadly there are plenty of other things that take the edge of a great new upgrade too...
:P
I've used FF 2.x for ages and it was reliable etc etc. This version does some really odd things.
I played with this attachment issue again and discovered if I click right on the message, I am allowed to select view picture. After I do this, I see the picture.
Weird.
...wouldn't expect anything less from you Eric! :-) Thanks for the smile!
I downgraded to FF 2.0.0.15 and the fault was still present. I considered that there was a config val still set somewhere. So I went through the about:config file looking for 'issues' but didn't find anything specific.
When I 'upgraded' to FF3.0, it went through my add ons and checked for compatability. I have since removed the JSView addon and the FF2 is behaving itself - except for spelling.
Hope the post is useful to others.
Stick :
about:robots
in the address bar.
about:config ok, about:robots - no show.
...and then I suppose I'll get FF3 and get on with my day again.
