Issues with LENGTH_STRING accuracy
mpullin
Hey Programmer types:
I'm hitting my head against a brick wall here: I must be missing something easy. Here's the scenario:
bufARQ1 is a CHAR array of size 256, that is linked via CREATE_BUFFER to the device dvARQ1, an AudioReQuest.
My DEFINE_PROGRAM is this: if(LENGTH_STRING(bufARQ1)) ARQ_PARSE();
ARQ_PARSE() does this:
DEFINE_FUNCTION ARQ_PARSE(){ STACK_VAR CHAR thisMSG[100] if(!FIND_STRING(bufARQ1,"$FF,$FB",1)) return; // no terminator thisMSG = REMOVE_STRING(bufARQ1,"$FF,$FB",1); SEND_STRING 0, "'arqMSG[',itoa(LENGTH_STRING(thisMSG)),']:',thisMSG"; }But sometimes the SEND_STRING 0 is reached when the terminator does not appear in bufARQ. Furthermore, when this happens, the length of the string thisMSG is being reported incorrectly!
Line 86 (16:05:47):: AudioReQuest 0:4:0 is ONLINE Line 87 (16:05:47):: IP: 10.1.10.65 Line 88 (16:05:47):: PORT: 3663 Line 89 (16:05:47):: arqMSG[4]:s$F1$FF$FB Line 90 (16:05:47):: arqMSG[13]:2!$01GRAPHIC$F1$FF$FB Line 91 (16:05:47):: arqMSG[16]:2$12$07Artists =>$F1$FF$FB Line 92 (16:05:47):: arqMSG[13]:2!$02GRAPHIC$F1$FF$FB Line 93 (16:05:47):: arqMSG[15]:2$12$08Albums =>$F1$FF$FB Line 94 (16:05:47):: arqMSG[13]:2!$03GRAPHIC$F1$FF$FB Line 95 (16:05:47):: arqMSG[15]:2$12$09Genres =>$F1$FF$FB Line 96 (16:05:47):: arqMSG[13]:2!$04GRAPHIC$F1$FF$FB Line 97 (16:05:47):: arqMSG[17]:2$12$0ANow Playing$F1$FF$FB Line 98 (16:05:47):: arqMSG[13]:2!$05GRAPHIC$F1$FF$FB Line 99 (16:05:47):: arqMSG[18]:2$12$0BPlaylists =>$F1$FF$FB Line 100 (16:05:47):: arqMSG[13]:2!$06GRAPHIC$F1$FF$FB Line 101 (16:05:47):: arqMSG[6]:2$12$0C$F1$FF$FB Line 102 (16:05:47):: arqMSG[6]:2$12$0D$F1$FF$FB Line 103 (16:05:47):: arqMSG[14]:2! Line 104 (16:05:47):: arqMSG[8]:2$12$03 Line 105 (16:05:47):: arqMSG[10]:2$12$02Home$F1$FF$FB etc.Regard lines 103 and 104. Is there some tricky thing with the length of the string going on? Anyone here know how this is possible?
Thanks Joe. I remember now that Diagnostics stops printing when it sees $00... but for some reason I didn't think that my problem could be in the diagnostics step itself!
If only we could see notifications from Ethernet devices directly.......
This would output '<0>' in place of any nulls without "breaking" the regular ASCII characters. I have another version that replaces the ITOA with ITOHEX if I want hex notation instead of decimal.
I normally convert my strings to ASCII in order to make sure what I am actually getting when doing send string 0... Two of the function I tend to use...
