Line 11 :: Error sending UDP packet (IP=EFFFFAFB) (Error=65) - 15:49:11
in AMX Hardware
Hello! Tell who knows, what it for an error?
Thanks.
Thanks.
IP адресс static, in a network 2 NI-3100, a problem that the controller to which it is connected CTG-LON and 6 VST thermostats hangs up.
Line 67 :: CIpEvent::AddInternalEvent - Error Overflow - 17:19:42
And such error.....
If the web server isn't opening, it's probably related to the processor being too busy due to an overloaded message queue. In other words, it's likely the same problem. Check the memory use on that master - if one of the modules is writing to the flash drive, you could be running out of memory. But it could as easily be too function calls getting allocated and not released because of the same traffic. Like I said, this is a tricky problem to find. If it ran for a year, what could have changed in that year? I still say it sounds like a device not responding properly and causing hangs that eventually back things up.
i to facing the same.......
But using amx Wifi with MVP-5200i touchpanel, the program i wrote working fine.
When i am diagnositing it giving UDP Paket (IP=EFFFFAFB)(Error=65).
Please suggest...........
Does it give you this constantly?
If it only happens now and then and your program isn't affected then you shouldn't worry about it.
It was happened with me too. Support said that it can be if Gateway and/or DNS addresses are empty.
After this I always fill they and this message is absent.
