R4 Comm Module
davieo
Hello,
I think I may have found a bug in the R4 Comm Module and wanted to throw it out here as a heads up, or maybe someone will tell me something I am missing.
I have an R4 remote that is controlling a bedroom system. The bathroom and deck off of this bedroom are separate audio zones. At the homeowners request, I added pages to control audio in these two additional zones on the R4. Thinking I was being smart I made the hard buttons for volume, mute, and power have different channel codes for the pages that are in the other rooms so I can map the hard buttons to different button events by what page they are on, instead of tracking it in code.
The volume and mute functions seem to be working fine. When I turn the power off for the room that I am controlling it works - the first time. The second time it does not.
Think this is strange I watched the push messages coming from the system. When the power button is pressed the first time, it comes from the virtual device, just as expected. Every time after that, it comes from the physical device.
This is only true in the rooms where I changed the hard power button to override the global setting in TPD4.
If anyone understands what I am saying, or can tell me I am doing something wrong - I would appreciate it. In the meantime I guess I will have to modify the code a bit...
There is a page flip in the panel file, I tried changing it and it made no difference. This only occurs with the power button, the other buttons that I am overriding work everytime. Very frustrating because referencing the physical device and button does not work either, probably because it is being eaten by the module.
Is starting to look like a long night...
Port number is 11, Channel numbers are 5 and 6 that are failing, but 7 and 8 on different buttons work...
So after reading the thread link submitted by Avophile, I tried changing this:
BUTTON_EVENT[vdvRM_BED1_VOL,6] //BED 1 DECK OFF
fnAUDIO_DISCONNECT(1,9) //this is a fucniton I wrote for the audio switches
to this:
WAIT 20
DO_RELEASE(vdvRM_BED1_VOL,6)
However, it still works exactly the same.
Looks like I will need to rethink this a bit - maybe a shutdown page, with room options...
