First Module Please Help
I have not yet gone to the training yet and I have some basic programming mainly AutoIt scripts. So I already know I have a system that is coming up that has 10 Leviton ViziaRF switches, this is all they want the system to control, via RS-232. So I am writing a module for this just incase I need it again I can just modify it if I need to go over 10 switches. I will be adding in scenes latter on when I get my hands on the system. So what I did was create 3 arrays for One array is all 10 of the Bright buttons, another for the Dim, and another for an On/Off toggle button. The buttons are numbered xzz, x = function (Bright, Dim, Toggle) zz = zone. Here is where I am at now. I know I probably have the Define Device of the RS-232 module set wrong. Any insight would be great.
Source
Module
I just notice that I get a syntax error when compiling the module, at the Toggle button, so I am looking at that right now
Source
PROGRAM_NAME='Vizia Test'
dvTP = 128:1:0
//Format is 1 = Bright and then the zone (switch) number upto 11
DEVCHAN dcViziaBright[] =
{dvTP, 12},
{dvTP, 13},
{dvTP, 14},
{dvTP, 15},
{dvTP, 16},
{dvTP, 17},
{dvTP, 18},
{dvTP, 19},
{dvTP, 110},
{dvTP, 111}
//Format is 2 = Dim and then the zone (switch) number upto 11
DEVCHAN dcViziaDim[] =
{dvTP, 22},
{dvTP, 23},
{dvTP, 24},
{dvTP, 25},
{dvTP, 26},
{dvTP, 27},
{dvTP, 28},
{dvTP, 29},
{dvTP, 210},
{dvTP, 211}
//Format is 3 = Toggle On/Off and then the zone (switch) number upto 11
DEVCHAN dcViziaToggle[] =
{dvTP, 32},
{dvTP, 33},
{dvTP, 34},
{dvTP, 35},
{dvTP, 36},
{dvTP, 37},
{dvTP, 38},
{dvTP, 39},
{dvTP, 310},
{dvTP, 311}
DEFINE_MODULE 'ViziaRF' md1ViziaModule(dcViziaBright, dcViziaDim, dcViziaToggle)
Module
MODULE_NAME='ViziaRF' (DEVCHAN dcViziaBright[],
DEVCHAN dcViziaDim[],
DEVCHAN dcViziaToggle[])
dvViziaRF = 1:7:0
INTEGER nSwitch
INTEGER nFunc
INTEGER nStatus
BUTTON_EVENT[dcViziaBright]
IF (BUTTON.INPUT.CHANNEL < 100){ SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-10),'BI'" }
ELSE { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-100),'BI'" }
BUTTON_EVENT[dcViziaDim]
IF (BUTTON.INPUT.CHANNEL < 200){ SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-20),'DI'" }
ELSE { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-200),'DI'" }
BUTTON_EVENT[dcViziaToggle]
IF (BUTTON.INPUT.CHANNEL < 300)
{ SEND_COMMAND dvViziaRF, "'>?N',ITOA(BUTTON.INPUT.CHANNEL-30)} = nStatus
IF (nStatus <> 0) {SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-30), 'OF'"}
ELSE {SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-30), 'ON'"}
ELSE
{ SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-300)} = nStatus
IF (nStatus <> 0) {SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-300), 'OF'"}
ELSE {SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-300), 'ON'"}
That being said, here's your toggle event all bracketed out . . . you should be able to find the problem MUCH easier.
BUTTON_EVENT[dcViziaToggle] { PUSH: { IF (BUTTON.INPUT.CHANNEL < 300) { SEND_COMMAND dvViziaRF, "'>?N',ITOA(BUTTON.INPUT.CHANNEL-30) } = nStatus IF (nStatus <> 0) { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-30), 'OF'" } ELSE { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-30), 'ON'" } ELSE { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-300) } = nStatus IF (nStatus <> 0) { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-300), 'OF'" } ELSE { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-300), 'ON'" } } }BUTTON_EVENT[dcViziaToggle] { PUSH: IF (BUTTON.INPUT.CHANNEL < 300) { SEND_COMMAND dvViziaRF, "'>?N',ITOA(BUTTON.INPUT.CHANNEL-30)} = nStatus IF (nStatus <> 0) {SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-30), 'OF'"} ELSE {SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-30), 'ON'"} ELSE { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-300)} = nStatus IF (nStatus <> 0) {SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-300), 'OF'"} ELSE {SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-300), 'ON'"} }= find the needleBUTTON_EVENT[dcViziaToggle] { PUSH: { IF (BUTTON.INPUT.CHANNEL < 300) { SEND_COMMAND dvViziaRF, "'>?N',ITOA(BUTTON.INPUT.CHANNEL-30) } = nStatus IF (nStatus <> 0) { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-30), 'OF'" } ELSE { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-30), 'ON'" } ELSE { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-300) } = nStatus IF (nStatus <> 0) { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-300), 'OF'" } ELSE { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-300), 'ON'" } } }= find the haystackBUTTON_EVENT[dcViziaToggle] { PUSH: IF (BUTTON.INPUT.CHANNEL < 300) // If switches 2 thru 9 { //This is the line I am getting the syntax error on SEND_COMMAND dvViziaRF, "'>?N',ITOA(BUTTON.INPUT.CHANNEL-30")" == nStatus //Check status IF (nStatus <> 0) // If status is on { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-30), 'OF'" //Set switch to Off } ELSE // if switch is Off { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-30), 'ON'" //Set switch to On } } ELSE // For switches 10 and 11 { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-300)" == nStatus //Check status IF (nStatus <> 0) { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-300), 'OF'" //Set switch to Off } ELSE { SEND_COMMAND dvViziaRF, "'>N',ITOA(BUTTON.INPUT.CHANNEL-300), 'ON'" //Set switch to On } } }I'm curious, what are you trying to do here?
Get the value of the switch gives the dimmer percentage 0 is off and set the variable to this value. the command to do this is >?N1 would do node (switch) 1
You're making the same mistakes that I made when I first started programming.
SEND_COMMANDs are meant for virtual / AMX devices
SEND_STRINGS are meant for real devices
So, to send the "command" to the device, you'll need to use SEND_STRING instead of SEND_COMMAND.
Next, you'll need to parse the received data. So, you're going to need a whole new section: the DATA_EVENT section. You'll assign nStatus there. But since 99.99% of devices can't respond faster than the processor, you're going to need to wait until you get a response back before proceeding with what to do with the answer.
DATA_EVENT[dvViziaRF] { STRING: // Is triggered when you get a string back from the device { // Process the string; you can use DATA.TEXT which is the text that is received in this event } }See if that makes sense....
I understand that now I just looked at some other modules. Now the question that rises up is that I am using the BUTTON.INPUT.CHANNEL to figure out the switch number am I able to set a variable in the BUTTON_EVENT to the zone and pass that to the DATA_EVENT, not sure if I am going about this the right way.
DATA_EVENT[vdvViziaRF] { STRING: { STACK_VAR char nData STACK_VAR char nStatus STACK_VAR char nNode SEND_STRING 0,"'Rcvd from Comm:',DATA.TEXT" // need to verify that 3 digits is received on all messages for xxx and yyy nData = ITOA(DATA.TEXT) // DATA Text is <NxxxLyyy x is Node L light level nNode = MID_STRING(nData, 2, 4) // returns Nxxx nStatus = REMOVE_STRING (nData,'L',1) // returns yyy from the data If (nStatus <> 000) // if light is not off { SEND_COMMAND vdvViziaRF, "'>', nNode, 'OF'" // turn light off } ELSE { SEND_COMMAND vdvViziaRF, "'>, nNode, 'ON'" //turn light on } } }It appears you're parsing the virtual device and not the real device. Is the real device dvViziaRF?
Next..... Without defining the size of each CHAR variable, they'll only be one character long. Need to do something like this: Not sure how big your variables need to be, so increase or decrease them accordingly. And I would use INTEGERs rather than CHARs for nStatus & nNode. See below.
Next... First, the incoming data is already "ASCII", so there's no need to convert it. ITOA is converting an INTEGER to an ASCII (or CHAR) variable. What you'll probably want to do is capture the entire string and manipulate it from there.
You could do something for the manipulation like this (and let's assume cData has the data we need to parse): ATOI will convert the numbers in a string up to the first letter into an INTEGER
Then, make you evaluations
IF(nStatus > 0) // if it's not off . . . { // SEND_STRING, device, Turn it off } ELSE // it is off . . . { // SEND_STRING, device, Turn it on }Take a look at this tech note, it should help you with parsing incoming data.http://amx.com/techsupport/techNote.asp?id=616
Also, for Hungarian notation, I generally use this set of rules...
dv - DEVICE, PHYSICAL
vdv - DEVICE, VIRTUAL
dc - DEVICE,CHANNEL
s - CONSTANT LITERAL STRING EXPRESSION
c - 8 BIT CHARACTER
n - 16 BIT NUMERIC
sn - SIGNED 16 BIT NUMERIC
dv_ - DEVICE ARRAY
ch_ - CHANNEL ARRAY
dc_ - DEVICE,CHANNEL ARRAY
c_ - 8 BIT CHARACTER ARRAY
n_ - 16 BIT NUMERIC ARRAY
sn_ - SIGNED 16 BIT NUMERIC ARRAY
Hope this helps!
After that, create a UI Module that integrates the user interface (ie. Button Channels).
You could use commands link: TOGGLE-2 or DIM-5 to control the Comm Module. That is if you want to go this far....
JJames you help is extremely appreciated thank you.
MODULE_NAME='ViziaRF_Comm' ( DEV vdvDEV, DEV dvDEV ) (***********************************************************) (***********************************************************) (* FILE_LAST_MODIFIED_ON: 04/04/2006 AT: 11:33:16 *) (***********************************************************) (* System Type : NetLinx *) (***********************************************************) (* REV HISTORY: *) (***********************************************************) (* $History: $ *) DEFINE_DEVICE DEFINE_VARIABLE VOLATILE CHAR cBUFFER[1000] // BUFFER FOR PHSICAL DEVICE RESPONSES VOLATILE CHAR cCMD_QUEUE[1000] // STORES STRINGS TO BE SENT TO THE DEVICE VOLATILE CHAR cLAST_COMMAND[5] // HOLDS LAST COMMAND SENT TO DEVICE VOLATILE INTEGER nWAITING = 0 // INDICATES IF WE ARE WAITING FOR A RESPONSE OR NOT VOLATILE CHAR cCMD[9] // COMMAND FROM UI VOLATILE CHAR cSCMD[9] // COMMAND TO ViziaRF VOLATILE INTEGER nDEBUG = 0 // TRACKS THE ON/OFF STATE OF THE DEBUG MESSAGES (***********************************************************) (* LATCHING DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_LATCHING (***********************************************************) (* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_MUTUALLY_EXCLUSIVE (***********************************************************) (* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *) (***********************************************************) (**************************************) (* NAME: QUE COMMAND *) (* PURPOSE: ADD A COMMAND TO THE QUE *) (**************************************) DEFINE_FUNCTION QUE_CMD (CHAR cCMD[]) { IF ((LENGTH_STRING(cCMD_QUEUE) + LENGTH_STRING(cCMD)) <= MAX_LENGTH_ARRAY(cCMD_QUEUE)) { cCMD_QUEUE = "cCMD_QUEUE,cCMD" } ELSE IF (nDEBUG) { SEND_STRING 0,"'ERRORM=Queue full - command rejected.'" }(* QUEUE IS FULL *) IF (!nWAITING) { SEND_CMD() } } (********************************************************) (* SEND A COMMAND TO THE DEVICE AND WAIT FOR A RESPONSE *) (********************************************************) DEFINE_FUNCTION SEND_CMD() { STACK_VAR INTEGER N IF (LENGTH_STRING(cCMD_QUEUE) >=5 AND !nWAITING) { cSCMD = cCMD_QUEUE SEND_STRING dvDEV, "cSCMD" ON[nWAITING] WAIT 20 'WAIT FOR RESPONSE' { IF (nDEBUG) { SEND_STRING 0, "'NO RESPONSE RECEIVED; SENDING NEXT CMD'" cSCMD = "" } OFF[nWAITING] } } } (***********************************************************) (* STARTUP CODE GOES BELOW *) (***********************************************************) DEFINE_START CREATE_BUFFER dvDEV, cBUFFER // PHYSICAL DEVICE BUFFER (***********************************************************) (* THE EVENTS GO BELOW *) (***********************************************************) DEFINE_EVENT (***********************************************************) (* THE ACTUAL PROGRAM GOES BELOW *) (***********************************************************) DEFINE_PROGRAM SEND_CMD () (***********************************************************) (* END OF PROGRAM *) (* DO NOT PUT ANY CODE BELOW THIS COMMENT *) (***********************************************************)<E000
<X002
<E000
The line that I need is the middle line.
I'd normally have:
data_event[vdvViziaRF] { command: { Stack_var char InCommand[10] InCommand = remove_string(data.text,'-',1) switch (InCommand) { case 'BRT-': send_string dvViziaRF,"'>N',data.text,'BI'" case 'DIM-': send_string dvViziaRF,"'>N',data.text,'DI'" case 'TOG-': { SEND_COMMAND dvViziaRF, "'>?N',data.text" //Status if (status) dvViziaRF, "'>N',data.text,'OF'" else dvViziaRF, "'>N',data.text,'ON'" } } } }if you need to que the commands, the commands would be parsed easiest if they were added to the que with delimiters ($FE,$FF maybe). Pull the next command out by remove_string looking for $FE$FF. Only parse the que if you find $FE$FF in it.
Pretty much want 1 button for each zone that toggles on/off the light and shows the status of the light. I also have another page on the TP for scenes but they are not sure they want to do that yet.
So this is what I have come up with so far.
PROGRAM_NAME='ClientXXX' (***********************************************************) (***********************************************************) (* FILE_LAST_MODIFIED_ON: 04/05/2006 AT: 09:00:25 *) (***********************************************************) (* System Type : NetLinx *) (***********************************************************) (* REV HISTORY: *) (***********************************************************) (* $History: $ *) (***********************************************************) (* DEVICE NUMBER DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_DEVICE dvTP = 128:1:0 dvViziaRF = 5001:1:0 (* Buad = 9600 data bits = 8 stop bit = 1 parity = no parity Handshaking = off *) vdvTP = 3301:1:0 vdvViziaRF = 3302:1:0 (***********************************************************) (* CONSTANT DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_CONSTANT INTEGER nTPButtons[] = { 2, //Light Zone 2 3, //Light Zone 3 4, //Light Zone 4 5, //Light Zone 5 6, //Light Zone 6 7, //Light Zone 7 8, //Light Zone 8 9, //Light Zone 9 10, //Light Zone 10 11, //Light Zone 11 201, //Scene 1 202, //Scene 2 203, //Scene 3 204 //Scene 4 } (***********************************************************) (* DATA TYPE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_TYPE (***********************************************************) (* VARIABLE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_VARIABLE VOLATILE CHAR cZone //Stores Selected Light Zone cStatus //Stores Status of Selected Light Zone (***********************************************************) (* LATCHING DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_LATCHING (***********************************************************) (* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_MUTUALLY_EXCLUSIVE (***********************************************************) (* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *) (***********************************************************) (* EXAMPLE: DEFINE_FUNCTION <RETURN_TYPE> <NAME> (<PARAMETERS>) *) (* EXAMPLE: DEFINE_CALL '<NAME>' (<PARAMETERS>) *) (***********************************************************) (* STARTUP CODE GOES BELOW *) (***********************************************************) DEFINE_START (***********************************************************) (* THE EVENTS GO BELOW *) (***********************************************************) DEFINE_EVENT BUTTON_EVENT [dvTP, nTPButtons] { PUSH: { STACK_VAR INTEGER nButtonIndex nButtonIndex = GET_LAST(nTPButtons) cZone = ITOA(nButtonIndex) Switch(cZone) { Case 201: { //scene } Case 202: { //scene } Case 203: { //scene } Case 204: { //scene } default: //If it is not a scene { SEND_COMMAND dvViziaRF, "'>?N', cZone" //gets the status of the Light Zone IF (cStatus = 'OF') { SEND_COMMAND dvViziaRF, "'>N', cZone, 'ON'" //Turn Light Zone On SEND_COMMAND dvTP, "'^ANI-', cZone,',1,2,0'" //Set TP Button to On } ELSE { SEND_COMMAND dvViziaRF, "'>N', cZone, 'OF'" //Turn Light Zone Off SEND_COMMAND dvTP, "'^ANI-', cZone,',1,1,0'" //Set TP Button to Off } } } } } DATA_EVENT [dvViziaRF] { STRING: { STACK_VAR CHAR cTemp cTemp =ITOA(DATA.TEXT) SWITCH(cTemp) { CASE 'X002': { cStatus = 'ON' } CASE 'X000': { cStatus = 'OF' } } } } (***********************************************************) (* THE ACTUAL PROGRAM GOES BELOW *) (***********************************************************) DEFINE_PROGRAM (***********************************************************) (* END OF PROGRAM *) (* DO NOT PUT ANY CODE BELOW THIS COMMENT *) (***********************************************************)I appreciate all the help, looks like I will be in school in December.
So, maybe something like this for the evaluation:
SEND_STRING dvViziaRF, "'>?N', cZone" //gets the status of the Light Zone OFF[nReady] WAIT_UNTIL(nReady) { IF(cStatus == 'OF') { // do something } ELSE { // do something } }and then in the DATA_EVENT:
SWITCH(cTemp) { CASE 'X002': { cStatus = 'ON' ON[nReady] } CASE 'X000': { cStatus = 'OF' ON[nReady] } }Or, you can simply do a WAIT...
SEND_STRING dvViziaRF, "'>?N', cZone" //gets the status of the Light Zone WAIT 8 // wait 0.8 seconds { IF(cStatus == 'OF') { // do something } ELSE { // do something } }And don't forget - SEND_COMMANDs are for virtuals or AMX devices - SEND_STRINGS are for REAL devices that you'll communicate with.
Thanks you mentioned this before and it slipped my mind
DEFINE_START cTPCount = 2 While (cTPCount < 12) { SEND_STRING dvViziaRF, "'>?N', cTPCount" OFF[nReady] WAIT_UNTIL(nReady) IF (cStatus = 'OF') { SEND_STRING dvTP, "'^ANI-', cTPCount,',1,1,0'" //Set TP Button to OFF } ELSE { SEND_STRING dvTP, "'^ANI-', cZone,',1,2,0'" //Set TP Button to ON } }Example: nLiteStatus would be integers, and their values would be set in the DATA_EVENT when parsing the response. On would be 1, off would be 0; this way, each pass of DEFINE_PROGRAM, it gets updated automatically.
Also, you need brackets around you proposed WAIT_UNTIL if you're going to do an IF/ELSE in it . . . it doesn't fall through.
WAIT_UNTIL(nReady) { // put IF/ELSE in here }Another thing, most devices aren't online at DEFINE_START, so you'll probably want to put a WAIT at DEFINE_START before doing anything. Typically, I set variables and trigger an All Off function 15 seconds after startup (DEFINE_START.)
DATA_EVENT [dvViziaRF] { STRING: { STACK_VAR CHAR cTemp cTemp =ITOA(DATA.TEXT) SWITCH(cTemp) { CASE 'X002': { cStatus = 'ON' ON[nReady] nLiteStatus[cZone] = 1 } CASE 'X000': { cStatus = 'OF' ON[nReady] nLiteStatus[cZone] = 0 } } } } (***********************************************************) (* THE ACTUAL PROGRAM GOES BELOW *) (***********************************************************) DEFINE_PROGRAM [dvTP, 2] = nLiteStatus[2] [dvTP, 3] = nLiteStatus[3] [dvTP, 4] = nLiteStatus[4] [dvTP, 5] = nLiteStatus[5] [dvTP, 6] = nLiteStatus[6] [dvTP, 7] = nLiteStatus[7] [dvTP, 8] = nLiteStatus[8] [dvTP, 9] = nLiteStatus[9] [dvTP, 10] = nLiteStatus[10] [dvTP, 11] = nLiteStatus[11]Something I noticed though in the DATA_EVENT.
cTemp will only be one character, and DATA.TEXT is not an integer - no ITOA. There's gotta be more to the parsing, yes? Don't forget to assign cZone or are you doing that in the button press?
STRING: { STACK_VAR CHAR cTemp[4] //4 characters cTemp =(DATA.TEXT) //Data.text is in X### SWITCH(cTemp)Also yes the cZone is being set on the Button Press
Also, since the zone is probably an integer, you may want to prefix it with an "n" and not a "c". Makes me think cZone is a character and not an integer, but know that's not possible when you put it in the array. Now we're getting picky.
Number one goal I feel in programming a system for a client, is to make it work. After that, it's efficiency. Get it to work, then clean up the code.
DEFINE_EVENT BUTTON_EVENT [dvTP, nTPButtons] { PUSH: { STACK_VAR INTEGER nButtonIndex nButtonIndex = GET_LAST(nTPButtons) cZone = ITOA(nButtonIndex) Switch(cZone) { Case 201: { //scene } Case 202: { //scene } Case 203: { //scene } Case 204: { //scene } default: //If it is not a scene { SEND_STRING dvViziaRF, "'>?N', cZone" //gets the status of the Light Zone OFF[nReady] WAIT_UNTIL(nReady) { IF (cStatus = 'OF') { SEND_STRING dvViziaRF, "'>N', cZone, 'ON'" //Turn Light Zone On SEND_STRING dvViziaRF, '>UP' //Updates all Vizia Controllers } ELSE { SEND_STRING dvViziaRF, "'>N', cZone, 'OF'" //Turn Light Zone Off SEND_STRING dvViziaRF, '>UP' //Updates all Vizia Controllers } } } } } } DATA_EVENT [dvViziaRF] { STRING: { STACK_VAR CHAR cTemp[4] cTemp = (DATA.TEXT) SWITCH(cTemp) { CASE 'X002': { cStatus = 'ON' ON[nReady] nLiteStatus[cZone] = 1 } CASE 'X000': { cStatus = 'OF' ON[nReady] nLiteStatus[cZone] = 0 } } } } (***********************************************************) (* THE ACTUAL PROGRAM GOES BELOW *) (***********************************************************) DEFINE_PROGRAM [dvTP, 2] = nLiteStatus[2] [dvTP, 3] = nLiteStatus[3] [dvTP, 4] = nLiteStatus[4] [dvTP, 5] = nLiteStatus[5] [dvTP, 6] = nLiteStatus[6] [dvTP, 7] = nLiteStatus[7] [dvTP, 8] = nLiteStatus[8] [dvTP, 9] = nLiteStatus[9] [dvTP, 10] = nLiteStatus[10] [dvTP, 11] = nLiteStatus[11]I was thinking I need a TO or While Statement that sets the zone like this.
DEFINE_PROGRAM nCount = 2 WHILE (nCount < 12) { cZone = nCount [dvTP, nCount] = nLiteStatus[nCount] }Interesting perspective. I tend to go the other way. Making it work is a far bigger challenge when your code is messy and unorganized. Often there isn't a chance to do any cleanup and the code stays that way.
Seconded. Usually I write something, get it working and implement it, then read something here and learn a better way I could have done it. Going back to "correct" already working code, seems to be more work than its worth. Just have to remember to do it the correct way the next time.
I am use to trying to condense my programs, if i can do in 2 lines what i can do in 10 then do it.
Word to that (or whatever slang for "I agree" is popular nowadays). One day, I would really like to post my very first programming job. I didn't know how to use arrays or anything. I did everything line by line. Really horrible. Then I went to class, joined this forum, and increased my AMX Jedi skills. Still have a long ways to go though. I would love so much to go back to that first job and "fix" it. But it is a conference room in Iraq, so I really doubt they would pay for my plane tickets just to go over there and make it better.
Now that I am thinking about that program, it makes me laugh. Not only did I not use any arrays, but I did not know how to properly manipulate strings. So, I hard coded everything. All of the perceived feedback to the touch panel, was written into the code. Like when they opened the mics on the Tandberg, the TP would indicate the mics were on even if the Tandberg was powered off. And the TP would probably win an award for AMX's worst designed touch panel. It all worked and met their requirements, but now that I am wiser and know better, I am really embarrassed by it.
Anyway, as to the DEFINE_PROGRAM question. If [dvTP,2] is always for lighting zone number 2, and nLiteStatus[2] is updated in the DATA_EVENT then what you had originally will work, no need for the loop.
And, I just looked further into your code . . . okay. cZone looks like it is a character, in which case, you cannot use it to designate a position in an array. A char "1" would be a decimal 49, which is probably too big for the array, so you'd be getting "runtime errors." You need a new variable, like nZone, which would be the equivalent to nButtonIndex, but global so that it could be referenced elsewhere in code. Unless of course, you did a ATOI on cZone every time you needed to get the decimal version of the zone - which, would not be recommended.
PROGRAM_NAME='ClientXXX' (***********************************************************) (***********************************************************) (* FILE_LAST_MODIFIED_ON: 11/05/2008 AT: 15:36:28 *) (***********************************************************) (* System Type : NetLinx *) (***********************************************************) (* REV HISTORY: *) (***********************************************************) (* $History: $ *) (***********************************************************) (* DEVICE NUMBER DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_DEVICE dvTP = 128:1:0 dvViziaRF = 5001:1:0 (* Buad = 9600 data bits = 8 stop bit = 1 parity = no parity Handshaking = off *) vdvTP = 3301:1:0 vdvViziaRF = 3302:1:0 (***********************************************************) (* CONSTANT DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_CONSTANT INTEGER nTPButtons[] = { // Individual Nodes 101, //Node 1 102, //Node 2 103, //Node 3 104, //Node 4 105, //Node 5 106, //Node 6 107, //Node 7 108, //Node 8 109, //Node 9 110, //Node 10 111, //Node 11 112, //Node 12 113, //Node 13 114, //Node 14 115, //Node 15 116, //Node 16 117, //Node 17 118, //Node 18 119, //Node 19 120, //Node 20 // Groups - A set of switches/Dimmers to behave as one node 201, //Group 1 202, //Group 2 203, //Group 3 204, //Group 4 205, //Group 5 206, //Group 6 207, //Group 7 208, //Group 8 209, //Group 9 210, //Group 10 //Scenes 301, //Scene 1 302, //Scene 2 303, //Scene 3 304, //Scene 4 305, //Scene 5 306, //Scene 6 307, //Scene 7 308, //Scene 8 309, //Scene 9 310 //Scene 10 } (***********************************************************) (* VARIABLE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_VARIABLE VOLATILE CHAR cType //Stores Selected Node Type VOLATILE CHAR cTypeData //Stores the type of device on feedback VOLATILE CHAR cNode //Stores Selected Light Node VOLATILE CHAR cGroup //Stores Selected Light Group VOLATILE CHAR cScene //Stores Selected Light Scene VOLATILE CHAR cStatus //Stores Status of Selected Light Zone VOLATILE CHAR cMessage //Stores Light Node/Group/Scene Level error information INTEGER nReady //Flag for waiting for response from Lights INTEGER nLiteStatus[400] //Stores Light Status for feedback on TP INTEGER nNode //Stores Selected Light Node for Array position INTEGER nGroup //Stores Selected Light Group for Array position INTEGER nScene //Stores Selected Light Scene for Array position INTEGER nType //Stores Selected Light Type for Array Position (***********************************************************) (* STARTUP CODE GOES BELOW *) (***********************************************************) DEFINE_START (***********************************************************) (* THE EVENTS GO BELOW *) (***********************************************************) DEFINE_EVENT BUTTON_EVENT [dvTP, nTPButtons] { PUSH: { STACK_VAR INTEGER nButtonIndex nButtonIndex = GET_LAST(nTPButtons) nType = nButtonIndex IF (nType < 200) { cType = 'Node' cNode = ITOA(nButtonIndex) SEND_STRING dvViziaRF, "'>?N', cNode" //gets the status of the Light Zone OFF[nReady] WAIT_UNTIL(nReady) { IF (cStatus = 'OF') { SEND_STRING dvViziaRF, "'>N', cNode, 'ON'" //Turn Light Zone On SEND_STRING dvViziaRF, '>UP' //Updates all Vizia Controllers } ELSE { SEND_STRING dvViziaRF, "'>N', cNode, 'OF'" //Turn Light Zone Off SEND_STRING dvViziaRF, '>UP' //Updates all Vizia Controllers } } } ELSE IF (nType < 300) { cType = 'Group' cGroup = ITOA(nButtonIndex) SEND_STRING dvViziaRF, "'>?GR', cGroup" //Gets the status of the Light Group OFF[nReady] WAIT_UNTIL(nReady) { IF (cStatus = 'OF') { SEND_STRING dvViziaRF, "'>GR', cGroup, 'ON'" //Turn Group On SEND_STRING dvViziaRF, 'UP' //Updates all Vizia Controllers } ELSE { SEND_STRING dvViziaRF, "'>GR', cGroup, 'OF'" //Turn Group Off SEND_STRING dvViziaRF, 'UP' //Updates all Vizia Controllers } } } ELSE IF (nType < 400) { cType = 'Scene' cScene = ITOA(nButtonIndex) SEND_STRING dvViziaRF, "'>?S', cScene" //Gets the status of the Light Scene OFF[nReady] WAIT_UNTIL(nReady) { IF (cStatus = 'OF') { SEND_STRING dvViziaRF, "'>S', cScene, 'ON'" //Turn Scene On SEND_STRING dvViziaRF, 'UP' //Update all Vizia Controllers } ELSE SEND_STRING dvViziaRF, "'>S', cScene, 'OF'" //Turn Scene Off SEND_STRING dvViziaRF, 'UP' //Update all Vizia Controllers } } } } DATA_EVENT [dvViziaRF] { ONLINE: { SEND_STRING dvViziaRF , 'SET BAUD 9600,N,8,1' } STRING: { STACK_VAR CHAR cTemp[17] // Max 17 characters in the received data from Vizia RS232 module cTemp = (DATA.TEXT) IF (length_string(cTemp) == 5) //If data is 5 characters it is an error or infomation { cTypeData = 'Info' cMessage = MID_STRING(cTemp, 2, 4) } ELSE IF (length_string(cTemp) == 9) //If data is 9 characters it is a level or status { cTypeData = 'Status' cMessage = MID_STRING(cTemp, 6, 4) IF (find_string(cTemp, 'N', 1) == 1) //If this is a switch or dimmer { cNode = "'1', MID_STRING(cTemp, 4, 2)" //Strip the >N0 and add 1 to the beginning for TP Node Button Number nNode = ATOI(cNode) } ELSE IF (find_string(cTemp, 'G', 1) == 1) { cNode = "'2', MID_STRING(cTemp, 4, 2)" //Strip the >G0 and add 2 to the beginning for TP Group Button Number nNode = ATOI(cNode) } ELSE IF (find_string(cTemp, 'S', 1) == 1) { cNode = "'3', MID_STRING(cTemp, 4, 2)" //Strip the >S0 and add 1 to the beginning for TP Scene Button Number nNode = ATOI(cNode) } } SWITCH(cMessage) { CASE 'L255': { cStatus = 'ON' ON[nReady] nLiteStatus[nNode] = 1 } CASE 'L000': { cStatus = 'OF' ON[nReady] nLiteStatus[nNode] = 0 } // RF Transmission Messages CASE 'X000': //No RF Transmission Error { ON[nReady] } CASE 'X002': //RF Transmission Error { ON[nReady] } // Errors sent from the Vizia RS-232 Module CASE 'E000': //no error { ON[nReady] } CASE 'E001': //wrong start of the string symbol { ON[nReady] } CASE 'E002': //Input buffer overflow. { ON[nReady] } CASE 'E003': //Can not start RF transmission. All buffers are taken. { ON[nReady] } CASE 'E004': //Can not start RF transmission because previous one has not finished. { ON[nReady] } CASE 'E005': //Unrecognized command { ON[nReady] } CASE 'E006': //Attempt to send the new buffer over RS232 before previous one had been processed. { ON[nReady] } CASE 'E007': //The send Message does not have data fields specified. { ON[nReady] } CASE 'E008': //Can not stop SUC mode. Node is SUC. { ON[nReady] } CASE 'E009': //EERPOM is busy, can?t store group information { ON[nReady] } CASE 'E010': //No devices with specified properties have been found { ON[nReady] } } } } (***********************************************************) (* THE ACTUAL PROGRAM GOES BELOW *) (***********************************************************) DEFINE_PROGRAM [dvTP, 101] = nLiteStatus[101] [dvTP, 102] = nLiteStatus[102] [dvTP, 103] = nLiteStatus[103] [dvTP, 104] = nLiteStatus[104] [dvTP, 105] = nLiteStatus[105] [dvTP, 106] = nLiteStatus[106] [dvTP, 107] = nLiteStatus[107] [dvTP, 108] = nLiteStatus[108] [dvTP, 109] = nLiteStatus[109] [dvTP, 110] = nLiteStatus[110] [dvTP, 111] = nLiteStatus[111] [dvTP, 112] = nLiteStatus[112] [dvTP, 113] = nLiteStatus[113] [dvTP, 114] = nLiteStatus[114] [dvTP, 115] = nLiteStatus[115] [dvTP, 116] = nLiteStatus[116] [dvTP, 117] = nLiteStatus[117] [dvTP, 118] = nLiteStatus[118] [dvTP, 119] = nLiteStatus[119] [dvTP, 120] = nLiteStatus[120] [dvTP, 201] = nLiteStatus[201] [dvTP, 202] = nLiteStatus[202] [dvTP, 203] = nLiteStatus[203] [dvTP, 204] = nLiteStatus[204] [dvTP, 205] = nLiteStatus[205] [dvTP, 206] = nLiteStatus[206] [dvTP, 207] = nLiteStatus[207] [dvTP, 208] = nLiteStatus[208] [dvTP, 209] = nLiteStatus[209] [dvTP, 210] = nLiteStatus[210] [dvTP, 301] = nLiteStatus[301] [dvTP, 302] = nLiteStatus[302] [dvTP, 303] = nLiteStatus[303] [dvTP, 304] = nLiteStatus[304] [dvTP, 305] = nLiteStatus[305] [dvTP, 306] = nLiteStatus[306] [dvTP, 307] = nLiteStatus[307] [dvTP, 308] = nLiteStatus[308] [dvTP, 309] = nLiteStatus[309] [dvTP, 310] = nLiteStatus[310] (***********************************************************) (* END OF PROGRAM *) (* DO NOT PUT ANY CODE BELOW THIS COMMENT *) (***********************************************************)I added some error messages the Lighting can kick back but I have not done anything with them yet, I have not decided if I want the error to send a message to the TP or not.
