Wireless "N" / 802.11n
jjames
                    Okay . . . I can only find small references to 802.11n routers. We have a client who feels he "must" have an "N" network. I spoke with AMX about it, and there isn't any real "evidence" from them regarding how well or unwell an 8400 with a g-card will do.
So - what is all of your experiences? Please post which wireless-n router / accesspoint you've used and the results. Thanks!
Is N even an official standard yet? Last I checked (admittedly, quite some time ago) there were differing implementations of it that weren't strictly compatible. I've never felt it offered much of a noticeable performance increase anyway, so I never felt bad about shutting it off.
I'm just trying to explore the options to present to the client. He's apparently needing it to transfer large files to 3 computers concurrently. He's gotta back up his stuff (big league lawyer) and we can't get a wired connection to his main computer, so it's gotta be wireless.
Thanks for the input!
With AP's only one device can talk at a time RTS/CTS (1/2 duplex) type connection which is why through put can actually me much lower than 54megs on a great signal. Depends on number of users. If only one can talk at a time every one else gets buffered and they alternate send/receive.
The initial independent test found that it had a rather limited range when compared to G or even B. The bandwidth was in most cases slower and when on the extremes of the range very much slower.
I bought one and an "N" card to test. It was worthless. I ditched them on ebay as fast as I could.
This combined with the fact that it aniliates pretty much the whole 2.4Ghz band makes it a rather poor choice.
I still love 'A'. I had it in my house and it rocked. It was fast and reliable. It's the Beta vs. VHS of WiFi.
You must have one of those clients who thinks, "It's new, it must be better..."
Copper or fiber glass is still the fastest by a long-shot.
I have a rule that when I hear an architect say, "everything is going wireless, isn't it?" I break a thumb.
If you really want to sink his/her ship, have them send a file and then show them how you intercepted it on your laptop from the driveway.
P.S.
I have only had one very BAD (With a capital B A D) experience with N. I would avoid it as of right now.
Exactly, I've used a few of them from time to time, for this very application. Works great, invisible to the end user and generally trouble-free, it is worth fitting some suppression if you have any motor devices on the same ring / circuit. I've got a pair of Netgear units running an internet radio in the kitchen, far fewer drop outs than the wifi for streaming.
If that doesn't work and you want to stay away from N you could use 3 sepearate AP's, each on their own SSID and RF channel and then just set up each PC to work on 1 of the SSID's. Then you could actually connect and multicast to the 3 PCs at the same time with data actually being transferred to each at the same time. Three concurrent 1/2 duplex connections.
Thanks a ton!
And well, it's seeming that anyone who's used ANY wireless-n has had bad luck in an environment with an AMX wireless panel, so . . . lemme ask this. Has anyone had GOOD luck with wireless-n yet?
Just repeat after me, " N is bad. mmkay."
I've used it a few times where I absolutely had to. It's a bit flaky, and requires resetting the box when it goes dodgy. You also have to consider a phase bridge on the electrical system to get full coverage if your original and destinations wind up on a different phase.
Has anyone found a wireless 'N' access point that will work with AMX touchpanels without configuring it to operate as a 'G' access point? Or is this just not going to happen until AMX provides an 'N' card to upgrade them?
We have an existing client that is demanding wireless 'N'. My experience so far has been that you need to turn the 'N' capability off for the AMX touchpanel to work. We have tried some of the Linksys 'N' access points.
An help would be greatly appreciate. Thanks
No they're just going to force us to use wireless N, no harm done!
.. Oh wait..
I highly recommend this system. You can use the AMX product if the access point they are offering fits your needs, but last I heard, AMX is only offering a small segment of the complete product line.
I installed our first system with the rebranded Ruckus controller and access points last week and everything worked really well.
The only hick-up was that the controller shipped without the newest firmware for the APs and Controller. We had to have tech support put the correct firmware on the FTP site.
All-in-all wireless N and MVP 5200 panels have both been functioning and the setup did not take much time at all.
