New feature for G4 panels
in AMX Hardware
Just a thought here, but I'm tired of walking across campus to reboot a panel. It would be sooooooooooo nice if the new firmware release for G4 panels had a section where we could setup for the panel to reboot itself if connectivity is lost for x number of minutes and the number of reboot attempts.
I guess telnet access is gone. Is that why you have to physically reboot it?
Confused. Are you saying you still have VNC? I've not experienced Modero Panels dropping offline. There was one time 4 years ago TPI4 had an application layer Issue that locked up the panel.
In addition to VNC, I also lose connection to the telnet & studio connections.
Why are you losing connectivity?
Like jazzwyld mentions, I would be concerned about losing comm on a regular basis.
--John
I have brought this up many times, but to date I haven't had a thumbs up. All I need is a N.C. relay tied to the controller and monitor the panel for an extended 'offline' occurrence and triger the relay. I have done extensive testing and like I mentioned it doesn't appear to be a panel issue but a network time out problem that is likely occurring when someone is mulit-casting across my sub-net. I am currently moving my sub-net to a Vlan where I can better isolate network issues. However this is and will take a long time and this is why I thought of this feature would be a nice solution for me. The other issue is that the panels that drop offline are never constant and move from room to room and building to building making tracking the problem very very hard to pin point.
