String from device
Please help to compare a line, It is necessary to execute action if in line from the device is (60)!!!
WHAT IS NOT CORRECT?
DEFINE_VARIBLE
SRING_FROM_DEVICE[50]
V INTEGER
DATA_EVENT[DV_LIGHTS]
STRING:
SRING_FROM_DEVICE=DATA.TEXT
LIGTS_CONTROL(SRING_FROM_DEVICE)
DEFINE_FUNCTION LIGHTS_CONTROL(STRING_FROM_DEVICE)
V=FIND_STRING(STRING_FROM_DEVICE, '60' ,1)
IF(V=1)
ON[TP,100]
ELSE
OFF[TP,100]
ON[TP,100]
DEFINE_VARIBLE
V INTEGER
STRING:
IF(V=1)
ON[TP,100]
ELSE
OFF[TP,100]
ON[TP,100]
DEFINE_VARIBLE char SRING_FROM_DEVICE[50] INTEGER v DEFINE_EVENT DATA_EVENT[DV_LIGHTS] { STRING: { SRING_FROM_DEVICE=DATA.TEXT LIGHTS_CONTROL(SRING_FROM_DEVICE) } } DEFINE_FUNCTION LIGHTS_CONTROL(char STRING_FROM_DEVICE[]) { if(FIND_STRING(STRING_FROM_DEVICE, '60' ,1)) { ON[TP,100] } ELSE { OFF[TP,100] } }See if that works better.
Whether it will work if a line from the device (30, statcx60,32)?
Is (30, statcx60,32) an ASCII string, or is it a mix of ASCII and decimal/hex code? If the string is literally "'(30, statcx60,32)'", the find_string should be true.
I am not assured that it is a line! And how to learn what is it?
Pick the one that works for you, but understand that some of the methods that use the processor could be cut off if a $00 code comes in.
P.S.
You should also be looking at a manual that defines the protocol being used. Without this, it can be done, but it is fairly difficult and very prone to unexpected strings not being interpreted.
I used Netlinkdiagnostic, comes string from device [80,36, statcp, 60,30]
P.S.
In the function, make sure you remove the last ON[TP,100] statement as I did. The statement gets executed regardless of the condition.
Works only when is not present 60 in line.
If you could describe what you want to happen in a little more detail, I might be able to suggest a change to the code.
On a picture the answer from the device. The program does not work, where an error?
PROGRAM_NAME='AMX'
MIO_R4 = 128:1:0
LIGHT = 5001:5:0
VOLATILE CHAR STRING_FROM_DEVICES[50]
DATA_EVENT [LIGHT]
ONLINE:
SEND_COMMAND LIGHT,"'SET BAUD 9600,N,8,1 485 Disable'"
DATA_EVENT [LIGHT]
STRING:
STRING_FROM_DEVICES = DATA.TEXT
LIGHT_CONTROL(STRING_FROM_DEVICES)
DEFINE_FUNCTION LIGHT_CONTROL (CHAR STRING_FROM_DEVICES[50])
IF(FIND_STRING(STRING_FROM_DEVICES[50],'60',1))
ON[dvTP6,3000]
else
Off[dvTP6,3000]
You are trying to perform the find_string function which requires a string as the argument.
is a single character. In my opinion, this shouldn't even compile, but apparently it does.
If you want to evaluate a string with this function it should be:
FIND_STRING(STRING_FROM_DEVICES,'60',1)
Also, you are using the same variable name (STRING_FROM_DEVICES) for both a global variable and a variable local to your function. The way that you have it will probably work as intended, but it might be confusing.
If to write so should work?
FIND_STRING (STRING_FROM_DEVICES, ' 60 ', 1)
example
will return "sending 12345678901234567890123456789012345678901234567890$0D"
whereas
will return " sending 0$0d "
