Help Compacting Code
There has to be a shorter way to do this. Any input?
BUTTON_EVENT[dvFRONT_DOOR_INTERCOM,1]		// BUTTON ON MET-ECOM AT FRONT DOOR
	SEND_STRING dvAUDIO_SWITCH, "'CL2I13O1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18T'"	// SWITCH ALL AUDIO SWITCHER OUTPUTS TO INPUT FROM DOORBELL INTERFACE
	ON[dvRELAYS1,1]										// TRIGGER CHIME ON DOORBELL INTERFACE
    RELEASE:
	OFF[dvRELAYS1,1]									// RELEASE TRIGGER FOR CHIME ON DOORBELL INTERFACE
	WAIT 20											// WAIT 2 SECONDS TO ALLOW TIME FOR CHIME TO PLAY THEN SWITCH ALL OUTPUTS BACK TO THE PREVIOUS INPUT
	    SEND_STRING dvAUDIO_SWITCH, "'CL2I',ITOA(nAUDIO_KITCHEN),'O1T'"
	    WAIT 3
		SEND_STRING dvAUDIO_SWITCH, "'CL2I',ITOA(nAUDIO_HEARTH),'O2T'"
		WAIT 3
		    SEND_STRING dvAUDIO_SWITCH, "'CL2I',ITOA(nAUDIO_LIVING),'O3T'"
		    WAIT 3
			SEND_STRING dvAUDIO_SWITCH, "'CL2I',ITOA(nAUDIO_DINING),'O4T'"
			WAIT 3
			    SEND_STRING dvAUDIO_SWITCH, "'CL2I',ITOA(nAUDIO_PANTRY),'O5T'"
			    WAIT 3
				SEND_STRING dvAUDIO_SWITCH, "'CL2I',ITOA(nAUDIO_LAUNDRY),'O6T'"
				WAIT 3
				    SEND_STRING dvAUDIO_SWITCH, "'CL2I',ITOA(nAUDIO_GARAGE),'O7T'"
				    WAIT 3
					SEND_STRING dvAUDIO_SWITCH, "'CL2I',ITOA(nAUDIO_DECK),'O8T'"
					WAIT 3
					    SEND_STRING dvAUDIO_SWITCH, "'CL2I',ITOA(nAUDIO_STUDY),'O9T'"
					    WAIT 3
						SEND_STRING dvAUDIO_SWITCH, "'CL2I',ITOA(nAUDIO_MASTER_BEDROOM),'O10T'"
						WAIT 3
						    SEND_STRING dvAUDIO_SWITCH, "'CL2I',ITOA(nAUDIO_MASTER_BATHROOM),'O11T'"
						    WAIT 3
							SEND_STRING dvAUDIO_SWITCH, "'CL2I',ITOA(nAUDIO_PATIO),'O12T'"
							WAIT 3
							    SEND_STRING dvAUDIO_SWITCH, "'CL2I',ITOA(nAUDIO_BASEMENT),'O13T'"
							    WAIT 3
								SEND_STRING dvAUDIO_SWITCH, "'CL2I',ITOA(nAUDIO_EXERCISE),'O14T'"
I'm also worried that I will need to cancel waits for example if the doorbell button is pushed again before all of the waits under the release are finished.
    jweatherjweather Posts: 320
    If you really want the commands spaced that far apart, look up timelines in the NetLinx help file to send them at nice regular intervals. If you want them sent as fast as the device can process them, look up command queueing on this forum to see some ideas for keeping a list of commands and sending the next one as soon as the device responds to the previous one.
    jjamesjjames Posts: 2,908
    Couple of things I noticed (we do the same thing with our doorbells).
    1) I don't think there are commas in the protocol to switch multiple outputs, so I believe it should be SEND_STRING dvAUDIO_SWITCH, "'CL2I13O1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18T'"
    2) I use a for loop to switch things back to it's previous source like so:
    FOR(nLOOP=1;nLOOP<=18;nLOOP++)
    SEND_STRING dvAUDIO_SWITCH,"'CL2I',ITOA(nAV_ZONE_SOURCE[nLOOP]),'O',ITOA(nLOOP),'T'"
    I've not run into a problem with the speed of the strings going out to the Autopatch, so the waits are not needed.
    Source information would be stored in nAV_ZONE_SOURCE instead of individual variables for each zone. Shown is what I'd do:
    DEFINE_FUNCTION fnDOORBELL2()
    	SEND_STRING dvAUDIO_SWITCH,"'CL2I12O1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18T'";
    	WAIT 20
    			SEND_STRING dvAUDIO_SWITCH,"'CL2I',ITOA(nAV_ZONE_SOURCE[nLOOP]),'O',ITOA(nLOOP),'T'";
    remeolbremeolb Posts: 79
    That worked great. Thanks for the help!
    a_riot42a_riot42 Posts: 1,624
    Why are you sending raw strings to the switch? Are you not using a module? One of the advantages of sending commands rather than strings is that you don't need to worry so much about queueing since the controller has its own queue for send_commands.
    If you use send_commands then you can do all the switching in one command without looping.
    a_riot42 wrote: »
    Only if all the zones needed to return to the same source, however if the bathroom was listening to the radio input, and the kitchen was listening to the AudioRequest, you can't send a single-line command to switch them can you?
    Does the protocol support something like so?
    CL2I1O1I2O4I3O5 6 7T
    I've not seen the module, but I know for one the typical reason not to use modules is because they're so bloated. Plus - the protocol is rather simple.
    dchristodchristo Posts: 177
    Another possibility would be for you to record a router preset before switching all of the output to the doorbell. Then after the doorbell has complete recall the preset to restore the router to it's previous config.
    --D
    Nice Tip
    dchristo wrote: »
    --D
    Hi Dave! Thanks for the timely tip.
    dchristo wrote: »
    --D
    Good Call! Don't know why I didn't think of that. Thanks!
    dchristo wrote: »
    --D
    I have looked for this option in the past, but did not find it in the Autopatch Precis LT. Any chance this has been added, or that I missed it in my search? I know that some switchers allow 1 or more such presets and it would really make my life easier if Autopatch units supported this.
    I haven't used the Precis, but the standard Autopatch command to record a preset is:
    RR#T, where # is the preset number.
    To recall a preset:
    --D
    shr00m-dewshr00m-dew Posts: 394
    Spire_Jeff wrote: »
    Yes, the Preceis DSP units support several presets.
    Kevin D.
    AMXJeffAMXJeff Posts: 450
    remeolb wrote: »
    You need to start thinking about using a pacing queue, there are alot of post in this forum that show you how to write and use a queue.
    shr00m-dew wrote: »
    Kevin D.
    I will give it a try. I never tried it, because I found this in the manual:
    Precis DSP
    General Commands and Conditions
    If the Level “ L” designation is omitted, the command is executed on the audio level. When entering BCS commands, either omit the Level designation or use Level 0 or Level 2 (Level 0 indicates all levels and the Stereo with DSP models only have one level).
    Does not support global or local preset commands
    Does not support auxiliary commands
    Supports using a colon ( : ) to designate a range of destination numbers in multiple number entries.
    Audio Commands
    Full DSP functionality (page19)
    Digital output volume control – absolute, relative and increment/decrement methods (page13)
    Verifying volume status (page15)
    Muting and un-muting outputs (page14)
    Digital input gain control – absolute, relative and increment/decrement methods (page16)
    Verifying digital input gain status (page18)
    If this actually works, it will be a HUGE time savings for me.
    P.S.
    I was talking about the Precis DSP :)
    Spire_Jeff wrote: »
    Hmm.. Good thing I don't always read the manuals. This is controlling a DSP 18x18 and works fine:
    SEND_COMMAND AUDIO, "'PASS=RR1'"
    SEND_COMMAND AUDIO, "'PASS=CL2I',ITOA(IA_DOORBELL),'O1:18'"
    SEND_COMMAND AUDIO, "'PASS=CL0O1:18VA-300'"
    WAIT 100
       SEND_COMMAND AUDIO, "'PASS=R1'"
    Kevin D.
    kbeattyAMXkbeattyAMX Posts: 358
    Array Driven
    All of my switcher code is array driven. I make all of the changes I need to a 2 dim array then do a send_command 'TAKE' My module parses the array and makes any switches that did not exist before and assembles the switching strings in as few send_strings as possible. I just save the current array of values if I need to get back to them. The array is passed to the module. I do this for Autopatch, and any other switcher.
