Error Message after Installation of VA 1.4.1.232
Hi everybody,
I'm new to all this and will attend Programmer 1 here in Switzerland next week.
I received a Disc to pre-Install the VisualArchitect on my Laptop prior to the course.
When I try to start the software I get the following Error-Message:
Invalid Version
The Device Databasehas not been properly installed; Version 1.3.50 is required.
Please install and then re-launch VisualArchitect.
I run Windows Vista Home Premium 32bit Service Pack 1 on the Laptop. Manually searching for that file in the AMX TechCenter or trying to get the WebUpdate to find it did not help so far.
Does anybody have an Idea or the possibility to get me the needed Version 1.3.50
Many thanks in advance.
Invalid Version
Device Database 1.3.50 is required
This error occurs when attempting to run VisualArchitect 1.4 on Windows Vista. Even though the user running the application may have administrator rights, this error occurs. The solution is to prior to launching VisualArchitect, is to select the desktop icon for VA and open up the properties dialog. After the property dialog is open, select the Compatibility tab and then select the check box for Run this program as an administrator.
We have received a few complaints on this message and have found an effective method to restore the application databse.
Try this:
Uninstall VA, uninstall Microsoft SQL Server (select the AMX instance AND the client support piece), manually delete C:\Program Files\Common Files\AMXShare\VASupportFiles\ and C:\Documents and Settings\All Users\Application Data\AMX\VisualArchitect\, then re-install VA (which will, in-turn, re-install MSSQL).
Hope you get yours working
David
PS I have XP Pro SP3
Kind regards,
Steve
http://support.microsoft.com/kb/968749
http://support.microsoft.com/kb/290301
Michael
