iPod Control
Greetings,
I am finally in a situation where I need to control an iPod.
I intend to use Sonance docks and will be controlling from several panels.
What module (Nelinx preferred over Duet) have people been using?
Any common pitfalls in integration?
Thanks.
Thanks.
The only other problem I am aware of is that the latest firmware for iPods prevents them from charging while docked in the iPort. They still function, but they will not charge and they will be running on battery while in use.
Thanks.
I imagine Apple got tired of warranty-replacing LION batteries burnt up by OEM chargers...
http://www.iportmusic.com/news_100708.html
I did hear something about the iPort only supporting charging via firewire, and the newest iPods only supporting USB, but I don't have official information regarding this, just second hand stuff
I think this issue is tied in with Apples decision to require all future "Made for iPod" accessories to have an Apple ID / authentication chip integrated as a form of licensing for Apple. It is taking time for all manufacturers to become approved and gain a supply for new models... Surely an uncompetitive act if ever there was one...
All I can say is that I'm happy the iPod Touch I recently bought was a 1st gen. because of this...
The 3.21 module as written uses the queing module for R4s. Has anyone tried without the queing module, especially since ZigBee Pro?
Thanks.
What kind of mods?
Didi you do these pre-ZigBee Pro?
I am using the module you refer to. I have the newer iPort FS-2 connected to an NI-3101. I am mostly using it with iPhone, but sometimes iPod Touch.
Quite often, the iPod will not come online in the module. Sometimes pressing the button on the iPort helps, sometime pressing the iPod online button in the module's UI helps.
I am trying to figure out what the logic is here. Any ideas?
Thanks.
Can an ipod touch on the same network as a NI-700 or AXB-NET talk to an Axcent3 controller?Sorry if this question may have been asked numerous times.
Eric
OK, so what can I do with an AXB-NET devices? I have a few spares laying around, can I network my AXCENT3 controllers, or are these only for connecting 1 AXlink device to another?
Eric
It's been a very long time since I looked at one of those, but as I recall, they used a proprietary protocol that was more than a little unwieldy. I could be misremembering, but I have long felt their usefulness was limited, and I never ranked them very high on my solutions list.
Not to mention they have some pretty oddball requirements that make the network setup quite a bear. They do, however, make great door stops.
DEFINE_MODULE 'iPort_IW5_Comm_dr1_0_0' DuetCode(vdvIpod, dvIPod)
DEFINE_MODULE 'iPort_IW5_UI' TP1(vdvIpod, dvRoomTpD, nIPodBtns, nTXT_BTN, nLVL_BTN)
I've not had much luck with the duet module. It seems to have issues staying online and in getting metadate.
I had all sorts of problems with that module. The NetLinx version has been rock solid for me. I did do a little editing of the UI module that is included to better handle how I work with multiple panels, but out of the box even the UI module works well. The nice thing is that the UI module code is included, so you shouldn't have to start from scratch.
P.S.
I have the NetLinx version working at one house that has 5 iPorts available and they have been working well.
I've been using the Netlinx module for quite some time now, and it just works. No problems.
Just remember channel code 142 to connect to the iPod!!!
