AXS File Backups
JoeJoe Junior MemberPosts: 99
I have noticed that TPD4 makes backup copies of touchpanels in the BackupFiles folder. I think it would be a great idea to have Netlinx Studio do the same type of archiving, for those of us who are periodically too stupid or too lazy to backup code or load it in the master and end up having to rewrite entire programs from scratch. The relative file size compared to a TPD4 project is extremely small and would be a tremendous benefit for those mentioned above.
    I'm in the manual backup mode. End of day and beginning of day (in case I was on the road), everything important gets synced to an external USB drive, and again at home to another computer (but less frequently on the home backup). My work computer goes home with me (laptop and docking station at the office), so I kind of get a poor man's offsite that way too since the computer and my primary backup don't "live" in the same place. I suppose if the office burns down and my car gets struck by lightning, I'm in trouble, but other than that I'm covered. I used an Internet backup site for a while, but as the files got bigger and bigger, it became more untenable.
  • arhanisinarhanisin Junior Member Posts: 1
    How?
    May I ask how you are managing to get the backups of the axs files from Netlinx. Our model is a NI-4000 and all I can see and download are the IRL files but nothing else. I've tried Rs232, telbet, FTP and TCP/IP but no luck. The only folder we can access is doc:user and nowhere else. Tthe administrator password and user are the default parameters but still cannot make it. Are there any other advices you may have for me to download my axs file back to netlinx studio for editing.
    Many thanks.
  • JeffJeff Junior Member Posts: 374
    Open up NetLinx Studio, go to Tools|File Transfer
    Now look at at the tabs across the top, and hit "Receive". press "Add". Select "Netlinx Source Code". Press Add Again.
    Type in the name you want to save the file as. Not a file you already have, a file you're going to create. hit Save. Enter the Device mapping as 0:1:0.
    Hit OK. Confirm your communication settings now, as they'll be the default settings you have, they won't be tied to the workspace you have open. Right click on the file and hit Communication Settings to change them. Hit Receive
    Now you have the .src file from the Master. Hit Tools|File Extraction|Extract from.src file.
    Automagically, you have all the .axs files.
    J
  • ColzieColzie Senior Member Posts: 470
    Jeff wrote: »
    J
    ....if they were sent to the master in the first place. Otherwise you get a "No source code was sent" message.
    True. But he was asking about how to bring them back to NS Studio for editing . . . . so I don't know why that would be a consideration. Clearly he's already put them on the master and tested and used them.
    Having your only backup on the master controller is not a wise idea. If you or someone else uploads different code, bye bye backup.
    As stated previously, backing up from your PC is the way to go.
    I have two Netgear SC-1 Storage Centrals. They are cheap and effective. I back up my workstation to one of them at 2am and the second at 3am automatically. They are located in seperate buildings just in case of fire, etc.
  • John GonzalesJohn Gonzales Junior Member Posts: 609
    Jeff wrote: »
    Colzie might be referring to the "build with source" option being unchecked on Studio, in which case there would be no .src file to download or extract from the master. As long as "build with source" is checked in the preferences tab, receiving and extracting the file would work.
    --John
    --John
    That is correct.
    Some programmers or companies are paranoid about code theft and do not put the source code on the master. I personally think not putting the source code on the master is a bad idea.
  • roognationroognation Junior Member Posts: 138
    Getting compiled code file(s) FROM a Master
    I am not usually working with other people's code, but we just got called in to do a service call for a system that was installed by a company that has since gone out of business. The code worked fine up until a week ago, but it seems one of serial ports is no longer functioning. I assumed I could go in with NetLinx Studio and "receive" all the files running on this master to install them on another new unit.
    Well, this master does not have the SRC files parked on it. And I don't see an option for "receive" TKN or TOK files in NS.
    I assume I need to do some FTP voodoo or worse: compact flash swap...
    Any hints?
    Thx!
  • ScottpulmanScottpulman Junior Member Posts: 48
    If its a Netlinx master, you receive the SRC file, extract it and nothing is there, then nothing can be done. You are SOL.
    This has happened to me a few times, as for some strange reason I spend a lot of time in other peoples codes, and pretty much the only option available to you ( as far as I know ) is to rewrite. Rewrites suck, as 9 times of 10 you need to do absolute discovery about a system, whats connected to what, and how its connected and that eats up a lot of time and effort.. but i digress.
    The only thing that I can say is that I feel your pain and frustration.
    Or you could just try placing the CF card from the master with a non-working serial port into another master to see if it's hardware related.
    If it's programming related then it sounds like you'll get stuck doing a rewrite.
    -John
    Thanks, I thought I was going crazy. What a terrible predicament. I have an email in to tech support (will that cost me $ 1200?) to further this. I will edit this response with any result.
    [edit]
    Yup, one must have the SRC file intact. No way to FTP or retrieve the TKN file(s) otherwise.
    roognation wrote: »
    Thanks, I thought I was going crazy. What a terrible predicament. I have an email in to tech support (will that cost me $ 1200?) to further this. I will edit this response with any results.
    Roognation
    I don't think tech support can help you either. If the source isn't there, it isn't there. You might be able to extract the compiled files and load them on a new master, but I don't think AMX officially supports that, and your call will be wasted.
    What I generally do in such situations is offer the customer a quote on (1) pulling the unit and repairing it, and (2) a discounted re-write. You need to warn them that doing the first might necessitate the second; sometimes they can't save the running code.
