RMS Configuration program won't launch
cvarner
I am working (remotely) with a customer to install RMS. We ran the installation software (with no errors), but for some reason when I open up the RMS Configuration Wizard it crashes. I checked the windows error log and found the following error:
Faulting application RMSConfigurationwizard.exe, version 3.3.0.85, time stamp 0x4a8ec813, faulting module ntdll.dll, version 6.0.6002.18005, etc...
I have attempted reinstallation and rebooted the machine a couple times. Any ideas?
Here is some more info:
Machine type: Virtual server
OS: Windows server 2008 sp2 standard edition.
2 Gigs of RAM
IIS 7.0
.NET 3.5 + ASP.NET 2.0.50727 framework
SQL Express 2008
I am connected to the server via a Remote desktop session.
Windows firewall is off
Both SQL and RMS are being installed on the \ drive
Customer says we have full admin rights to windows.
2 Gigs of RAM
IIS 7.0
SQL Express 2008
Thank You,
Robert
is your problem solved already (hopefully it is as this thread was started two months ago...)? I have a document from AMX which helps in configuring the Windows Server 2008 features to run RMS configuration wizard correctly (I assume your problem is/was related to server 2008).
-Kari-
PS - I had the same issue until I spoke with them.
I am also facing the same problem.can any anyone give me the solution?
Thanks in advance.
First ....
This is probably where it is falling down, some IIS component missing..
And now, yet another wizard will start....
That should be all the pre-req's as far as the server side stuff goes, after you complete the addition of those roles and components you can install SQL on that server if it isn't on a separate server, and then away you go.
And now we shall let the dead thread rest in pieces.
