IS-SPX-1000
Hi All,
Does anyone know what are the video formats playable on the IS-SPX-1000?
Thanks very much.
Thanks very much.
http://amx.com/products/IS-SPX-1000.asp
I have been looking for the list of formats, resolutions and frame rates accepatable for the software. I was trying to import video files with high resolution and the software couldn't accept it.
It would be helpful to have the list and do you have any recommendation on which software would be good to resize and convert video files?
Thanks.
"Up to SD resolution: MPEG-4 ASP, MPEG-2, MPEG-1, H.264, MJPEG, Microsoft VC-1 (Windows Media Video 9)"
which suggests that you aren't going to have much success with 'high resolution' video formats. It also states:
"If your IS-SPX-1000 is not successfully importing an SD video of the supported
file type, it was likely created with an unsupported codec or the file size is too large. If this is the case, try to
convert the video to a supported codec, using one of the many available tools for video conversion. The best
target format is the MPEG4 codec in the mov or avi file format."
The programming guide would suggest 720p @ 10fps or SD @ 30fps as that appears to be what the PowerPoint import process uses.
I agree with you. The video I was importing was too large, certainly there should be limitation for which resolution on which frame rates.
It would be great if the list was provided as guidelines and would be much better if it supports HD.
Thanks guys.
Have you had any success with live streaming video ? It's suppossed to support SD video in WMV format via RTSP/MMS/HTTP, however I didn't have much luck with the demo. Just sits there buffering.
Dave
I haven't try the streaming feature. Am I missing out the details or the manuals don't say anything about it?
Do you have any information on doing the streaming? I would like to give it a try.
Thanks.
"Streaming media protocol: MMS, RTSP, RTP, SDP, HTTP; Uni- & multicast"
A couple of the AMX sample projects I downloaded ( ISX_Retail_Advanced ), included an example of a streaming video source. Looks like AMX have updated the sample projects since then though to match the AMX University ones at:
http://www.thinkinspiredsignage.com/products/inspiredXpress.aspx
Unfortunately my evaluation period has expired, so a bit late for me to try these new samples out.
Dave
PS The ISX_Retail_Advanced demo just had a .asx metafile dragged into the project containing an entry to the following stream:
mms://stream1.france24.yacast.net/f24_livefr
(see attachment)
Any suggestions?
Didn't work for me either, even though I could playback the demo stream in Windows Media Player.
Dave
http://www.amxforums.com/showthread.php?7599-How-about-an-Inspired-Signage-thread
There might be a bit more info but I agree that some of this info seems to be well hidden. I'm starting to do more with IS-SPX but having some challenges with the "simple, intuitive software interface"! Maybe it's just me!
No, it's horrible. It's one of the least intuitive applications that I work with on a regular basis.
I have to agree. Once you know what's going on, it's relatively simple to use, but intuitive, no. I couldn't make heads or tails of it until I watched all the training videos.
This is an issue. Many of the customers who we would otherwise sell this flavour of signage to have a staff member who does lots of things and just happens to look after digital signage as one of their jobs.
Because they only spend time working with the product on occasion, the increased uptake time and retention of knowledge required to use the product really hampers its usability.
In many cases I don't feel confident that the ISXpress solution is a good option for the client due to the lack of intuitiveness in its authoring/publishing software. Obviously S****tix falls into the same category.
AMX has a 2-day classroom training session (new for 2011) that will guide you through the IS Xpress content management software. There is a session scheduled for March in the Chicago training center and other AMX training locations throughout the year.
My own experience is similar to others...very easy to use once you get the hang of it.
