Remote access/port forwarding w NS3?
I have set my router to port forward 1319 to the IP of my netlinx master(let's call it 192.168.1.50), but when I try to connect to it remotely, I get no response. I have a static IP for my high speed connection, but I can't even ping that IP when I'm remote. Is my provider blocking inbound requests? What else can I try to make this work?
Does the router have the ability to set an alternate port for it's web interface for remote management? If so set it to something that's not typically blocked like port 80 is, say 1280 or something and see if you can remotely access the routers web interface https:// or normally http://public.ip:1280.
Kevin D.
Exactly what I would check first. Been bitten by this one too.
