Lutron over IP
bneal
I have been trying to get a lutron P5 system to work over IP. I have had it working when we first installed it, then it stopped working randomly. It is sending messages to the virtual device which I can see in the network tree. It sends the same message back though. Is there anything special I need to do in the program or Lutron side to get it to work.
From what I recall AMX requires a Lutron user to login. If the other Lutron user logs in it can only handle one user at a time so the AMX stops communicating. You have to log off the other user and relogin as the AMX user I believe. This can happen if the lighting dude logs in to make changes without letting anyone know.
The HWI documentation specifically included recommendation and full set up instructions for using a DIGI-ONE SP IP to Serial adapter ($130 at Amazon and a billion other places) if you wanted to integrate 24/7 control. It said to use the TELNET IP connector only for technician uses.
I don't know if they still do admit all this, but the IP port did not support a stateless IP connection last time we looked.
It might be polling is required to maintain the connection at least at 30 second or 3 minutes intervals(?). Maybe that's something else that uses telnet.
Also no problems, if there is no connection it re-connect, but also no issues with that.
