USB file transfer error on an 8400?
                    I'm trying to transfer a modified TPD file to an 8400 via the virtual master option in TPD4.  It displays the panel as available in the list of USB connections, but once I start transferring, it gives me an error:
Error performing action Remove Remote System Files: Device returned file transfer NAK code 0x000d: Error removing directory.
Can this be fixed? I transferred the new project to the master, but now I can't get this panel loaded! Kinda stuck now...
Got it figured out. I was trying to do a smart transfer. As soon as I told it to do a full transfer and delete the old files, all was good. Got a little scared after that, though - I was using the USB connection, so I changed it back to ethernet and rebooted - got stuck on the AMX logo screen. Pulled batteries, and all is good for now.
My experience with it has been that if you've transfered a file within the past day or so it seems to work. But, go a length of time from the last upload, crashes the upload, more-than-likely crashed the application and in some cases crashes the touch panel, thus forcing you to do a 'Full Transfer.'
I'm still amazed when a file transfer takes down the whole application. That just blows my mind. I don't work in any other skd that does this. They all seem to be able to handle a blown file transfer without dying.
+1 on every single point.
Always make sure that you pull the USB cable out before rebooting or the lockup on reboot is bound to happen.
