AMX DCS and volume control
PatG
I'm programming a Navaro CP-3008 for the first time, and you have to do it using an app called AMX DCS. I want to use the volume pot on the panel, but the Sharp TV I'm controlling doesn't have a command for volume increment or decrement, you have to send a specific value to set it to. DCS doesn't allow for the use of variables so I can't change the value sent each time, I can only attach a string to a single turning direction. Any ideas much appreciated.
