Font rendering
I've been tweaking NS a bit so that it would better suit my needs (colours etc) and I've been trying to find a font that NS actually renders well.
I've tried Andale Mono, Terminus, Fixedsys and a whole lot more. Unfortunately there isn't a single font that renders well on all sizes. I'm using Dejavu sans mono now because that's the only font I found that renders remotely well in NS at 10 points. The rest just looks bad.
Has anyone been able to tweak NS/Windows in such a fashion that it renders it all well? Or at least a single font well at multiple point-values?
Edit: Here's a comparison of it. Same typeface same size.
    I'm using Courier New. It may be the default but I do know I've tried many fonts and this is what 've been using @ 10pt. Works fine for me.
    I use Trebuchet MS 14. My eyesight is pretty well shot. So, I use the fat font colors-on-black background.
  • the8thstthe8thst Posts: 470
    I am using Consolas @ 10pts for the font in all of my editors. The font was created for Vista and is included in Vista and Win7.
    This is also a good tool to get text looking better in Win XP. http://www.microsoft.com/typography/cleartype/tuner/tune.aspx
    Let me know if you want me to send you the font.
    -- edit -- I just noticed that the font looks fuzzy in the screen shot, but that is only because of the quality settings of my screen capture utility.
  • Jorde_VJorde_V Posts: 393
    For some reason it seems to render dejavu mono on a dark background much better than on a light background. So I switched to my dark theme again and now it looks fine.
    This is @ 10 points.
    the8thst wrote: »
    ClearType Tuner, works pretty good. Sharpens the text up nicely, thanks for the link!
  • Here is the font Consolas in 11 points. I like it.
    Bitstream Vera Sans Mono
    I might add, since I saved the screenshot as a jpg, it's quite a bit fuzzier looking here than it really is ....
  • PhreaKPhreaK Posts: 966
    10pt Consolas here as well...
    PhreaK wrote: »
    I like it. The colors are very Vim-esque.
    Speaking of Vim... We should turn this thread into (or start a new thread) repository of color schemes.
    I have attached a zip file with my editor prefs (only the editor option was checked) and the consolas font. Hopefully other will follow suit.
    the8thst wrote: »
    I think there has already been one about a year or so ago. But, it is fun to see what all y'all do.
    e
    I included my preferences as well. (just the editor, so you can easily try it if you want to).
    @the8thst, thanks for the link with the tuner. Fixed the font quite a bit. Now I can look at it and rejoice compared to before.
    I would love it if I could tweak specific things a bit more.
    And some things should be fixed like the operator including () and {}. [] are not included, but I want .,;:=+- etc to be separate.
    Guess I can only dream.
    I went to a darker theme and smaller font after seeing someone's screen - it just looked cleaner.
    Here's mine - but I'm going to take Jorde's for a spin today. Looks pretty modern.
  • rfletcherrfletcher Posts: 217
    I bounce between Courier New 10 and Liberation Mono 11 depending on which font size I feel like. Courier New doesn't seem to render as well at 11 point as it does at 10, and Liberation Mono is absolutely atrocious below 11 point (the tops of [] don't even show up at 10 point). I've been using basically the same colors since just after I took programmer 1. Here's a screencap
    And here's the editor prefs and Liberation Mono if anyone wants it
    ericmedley wrote: »
    e
    Yup, and the differences in how we all format code are just as interesting as the editor preferences :)
    rfletcher wrote: »
    Editor preferences:
    Code formatting: Style Guide
    PhreaK wrote: »
    Editor preferences:
    It's nice to see that my natural progression was moving me towards being in compliance with that style guide.
    The only exception is that I prefer mixed case naming conventions instead of using _ to separate words.
