Tango audio without SWT
overclocker
in AMX Hardware
Does any one know if the Tango audio controller/amp ( 8X4 ) can be used without the SWT kepads? I want to control via RS232 only. I can do so, however one of the channels on four zones is out.
We commonly use them on RS232. I don't know what you are asking about the channel being out, it is NOT because you are controlling on RS232 if that's the actual question. If one channel is out on all four zones, you may have your balance set all the way to one side.
But I've used them as multiroom switches and nothing else, they are fine for that purpose and you don't need to have any keypads. That said, for the price you may as well just use a matrix instead. I only did it because I had one lying around doing nothing anyway.
