How far will IR travel?
Kenny
in AMX Hardware
Does anyone know how far I can run an IR cable?
I need to run IR to a TV and the cable length will be about 60 feet.
We will probably use the standard AMX IR emitter. Is there a better one to use for this purpose?
Kenny
Kenny
Sent from my MB860 using Tapatalk
I agree. Once i controlled a B&O DVD Player in that distance (and keep in mind that B&O equipment are using high IR frequencies in 455 KHz). The player was in the ground floor and the NI-3000 in the basement.
Kostas
I took a 1000' box of cat 5 coupled the pairs together,ir port to blue pair, coupled to orange pair, coupled to green pair, coupled to brown pair connected to device and it worked fine, in essence going over 4000' of copper. BTW my employer at that time had to part with $100 as he bet this would not work. Of course I tested it prior.....
