IR Not Working ?
tkelleher
New to here, Completed the Programmer course and in the process of setting up a demo Project in our demo room with Ni900 and TP. Have a Projector, DVD player and Amp connected via the included IR emmiters to port 2,3,4.
However I have a problem with the IR control as I cannot get the IR controlled devices to work. It is like the ex IR hex commands are not sending as per the pronto. I pasted in the hex codes to IR edit i had confirmed working from a pronto. The Ni900 is sending the ir pulses out as i have the leds blinking and i have placed a wirless ir transmitter close to the emmiter which flashes red when it recieves the ir data from the emmiter.I even fitted a Xantech emmiter and its led on the emmiter flashes when the codes are sent.
I think my code is good and i have tried, pulse and SP commands (playing with the CTON times). I have also tried directly via IR edit adjusting the pulse times.All the equipment firmware is up to date.
Could anybody give me some advice please?. or point me in the right direction?
If those work then you have bad codes or are not getting your codes imported correctly.
Got it working and the fault was my Hex IR codes. I played around with learning them in again and copied & pasted several versions into notepad to clean them up.
