Axcent3 Program Port over TCP/IP
fongslb
in AMX Hardware
hi all,
ok, am needing to support a Axcess system remotely. Has anyone ever used a serial-to-ethernet device server (e.g. MOXA NPORT 5100A), to connect to an AMX serial program port via TCP/IP? Want to check this option out before I actually recommend getting a unit and testing it over VPN.
Regards,
Brian
Regards,
Brian
I have done exactly that with a Moxa N-Port (don't remember the model) and it worked just fine. There was a piece of software that needed to be installed in the PC to create a virtual comm port because studio will not accept a TCP/IP connection for an Axcess master.
Of course if you're end device is 500 miles away there may be other timing issues beyond your control.
+1
Plus some stuff to make the message long enough.
