Video Distribution with priority of control
Hello All,
We are looking for a solution for HDMI Video distribution to 24 zones.
8 Video sources ( 4 Decoder, Apple TV, Media Player, Du TV) all with HDMI connector type.
We are looking for followings functionality :-
1) All the video source need to be distributed to 24 zones.
2) Whoever selects a video source first, control via IR should be disable in other remaining zones.
    First you need a switcher capable of at least 24x8 so how deep are your client's pockets? Just Add Power would be the least expensive option that I can think of and AMX's EnovaDGX32 would be the most expensive.
    Everything else is just coding but it sounds like you're looking for a pre-package out of the box solution and that doesn't exist. You first need to find a switcher capable of what you want for the money the customer is willing to spend and that may be you biggest hurdle. Then you need to write a program or hire a programmer to do what you need and that too is also fairly expensive.
    Are you at least a programmer? What type of client is this and what's the budget?
  • MMehtaMMehta Posts: 2
    vining wrote: »
    Hi Vining,
    Thanks for your reply.
    Well client is fine with budget, but can we achieve the following functionality as below:
    1) Whoever selects a video source first, control via IR should be disable in other remaining zones.
    MMehta wrote: »
    Hi Vining,
    That's simple to do in code.
    Out-of-the-box software that does that DOES exist (ours does it). But I suspect these requirements are just the tip of the iceberg.
    John Nagy wrote: »
    I wouldn't consider CineTouch to be an "out of box" solution since it's really an all or nothing solution. I can't see an existing system that now needs 24x8 hdmi switching with the specified abilities being easliy handled by CineTouch with out re-vamping the entire system's code structure. Plus all the existing devices would need to be supported by CineTouch.
  • jimmywjimmyw Posts: 112
    Go with Just Add Power, add a 48 port dell gigabit managed switch, call er done., the rest is just a little code.
    Add 1 transmitter for each source, and behind each tv put a receiver. they recommend cat6 but I have had great luck with existing installs with cat5.
  • PhreaKPhreaK Posts: 966
    MMehta wrote: »
    but can we achieve the following functionality as below...
    Anything can be achieved, its just a matter of time and budget. But yes, in your case that functionality is quite simple to implement.
