Array of Strings
Is it possible to do an array with strings (or characters) in it?
I'd like to reference this by array index
cINPUTNAMES[] = {'INPUT #1', 'INPUT #2', 'INPUT #3', 'INPUT #4', 'INPUT #5', 'INPUT #6', 'INPUT #7', 'INPUT #8', 'INPUT #9', 'INPUT #10', 'INPUT #11', 'INPUT #12', 'INPUT #13', 'INPUT #14', 'INPUT #15', 'INPUT #16', 'INPUT #17', 'INPUT #18', 'INPUT #19', 'INPUT #20', 'INPUT #21', 'INPUT #22', 'INPUT #23', 'INPUT #24', 'INPUT #25', 'INPUT #26', 'INPUT #27', 'INPUT #28', 'INPUT #29', 'INPUT #30', 'INPUT #31', 'INPUT #32' }
  • mpullinmpullin Posts: 949
    You were pretty close. You just have to put an extra [] in there, i.e. VOLATILE CHAR cINPUTNAMES[32][10]
    A string is an array of chars. What you are declaring is an array of arrays of chars. What I wrote above describes an array of 32 strings and each one contains at most 10 chars.
    cINPUTNAMES[2] -> 'INPUT #2'
    cINPUTNAMES[2][8] -> '2'
    I'm assuming this was an academic example and you are going to be storing more interesting strings than 'INPUT #2' - otherwise you could just use itoa and forgo the array altogether :)
  • HedbergHedberg Posts: 671
    In my experience, declaring 2d character arrays is a bit tricky. The following seem to work:
    char sSTR[][3] = {'abc','def'}
    char sSTR2[][] = { {'a','b','c'}, {'d','e','f'} }
    while this does not:
    char sSTR3[][] = {'abc','def'}
    jabramson wrote: »
    Yes - Here's an example:
    CHAR cTransportMap[19][6]	= {
       {'PLAY'}, 	//1
       {'STOP'}, 	//2
       {'PAUSE'}, 	//3
       {'SKIP+'}, 	//4
       {'SKIP-'}, 	//5
       {'SCAN+'}, 	//6
       {'SCAN-'}, 	//7
       {'RECORD'}, 	//8
       {'POWER'}, 	//9
       {'NUM0'}, 	//10
       {'NUM1'}, 	//11
       {'NUM2'}, 	//12
       {'NUM3'}, 	//13
       {'NUM4'}, 	//14
       {'NUM5'}, 	//15
       {'NUM6'}, 	//16
       {'NUM7'}, 	//17
       {'NUM8'}, 	//18
       {'NUM9'} 	//19
  • travistravis Posts: 180
    Hedberg wrote: »
    char sSTR3[][3] = {
      {'abc'},{def'}
    travis wrote: »
    char sSTR3[][3] = {
      {'abc'},{def'}
    I beleive the earlier post just eluded to the fact that the second array needs to be defined.
    [] [] won't work
    but
    [] [3] will
    When dealing with 2 or more arrays the last array needs to be defined with a number in the brackets not just the array itself.
