DVX 3150 and Duet
Cameron
Hi Everyone,
I am having some real issues with Duet modules on a 3150, I cannot get them to talk back to the NI. Here is what happens;
I can see the tandberg getting polled on port 1 (5001:1:1) and it responds fine
I send the command ?VERSION to the vdv - I get no response except the command echoed back
I try using code based functions (in the TP) assuming that because polling is working somehow not doing it through netlinx may work - nothing
I have the newest firmware (pre release), lastest netlinx, latest cafe duet. I have loaded my code onto an NI-700 it works and an AMX Australia tech says it works on his DVX3150.
This is my second DVX with the same problem! Does anyone have any ideas, I am starting to doubt it being a hardware issue even though I have had an RMA raised.
Another thing - I was recieving Java errors on the web interface on the first DVX and this second one is really slow/loses connection. Could it be two lemons perhaps?
Cameron
Cameron
Thanks heaps for your responses!
Not for this one, at least not up until this stage
Tried that, it wouldn't recieve the DEBUG command either
41001 and 41002
It's strange this code works directly on an NI-700
Cameron
I tested the old NEC display jar (nec_plasma_comm_dr1_0_0.jar) against an NI3150HD running firmware 4.3.440
Sorry that didn't help. Did tech support have any additional information?
Why the multiple instances? You indicated defining 41001 and 41002 - do you have two codecs in your system? If so, do you have different module instance names? Does the stock workspace downloaded with the module work for you?
You also might need more Duet memory on your 3150. Most masters default to 3M, and that isn't necessarily enough if there is a lot going on with Duet modules, and it's very possible it was bumped up on your 700. Telnet into the master and type in "set duet memory," to check it or change it. Usually 8M is a more reasonable setting.
Thanks so much for all of your help & suggestions, I just came across this whilst looking for another thread and remembered I had not responded. AMX Australia (via US AMX) found that the Tandberg module on the AMX website is out of date and sent me the latest version. No problems now
Thanks again,
Cameron
