Other netlinx control questions related to my VC
Hi again AMX peeps,
Further to my last request about shutting things down. My codec takes about 5 mins to start up. I was thinking that if I could somehow get the bookings calendar to send a message to the amx controller, it could start up the codec 10min before the vc was about to commence, and then would be ready. Is there a way you can send a command like that? I have seen ip to rs232 devices, maybe I could use that to trigger the ni-3100??
David
David
Thanks for info. I will be working with the webteam to design a form for booking in the VC's I am hoping they can sort out their end. I will maybe give that i!-equipment monitor thing a go.
Regards,
David
