Home AMX User Forum AMX Resource Management Suite Software
Minimum firmware version for RMS
Howdy,
Is there a minimum version of firmware for the master and NI device recommended for RMS 3.3+?
Thank you
  • MorrisMorris Posts: 21
    Im not sure if this is a stupid question or nobody knows the answer.
    Naturally, I'm going with the latter ;)
    The documentation fails to mention anything about a recommended firmware version so I guess I am to assume it works on all versions.
  • If its Enterprise your planning on running you'll want to give tech support a call. 3.3 is a little more forgiving.
  • annuelloannuello Posts: 294
    Morris wrote: »
    I don't recall any specific fw requirement for RMS v3.3. While you can probably have any fw version on the master some are obviously more stable than others, particularly with the network stack. I try to run the same fw version on all masters (of the same model) so if there is a "ghost in the machine" I at least can rule out fw differences. IIRC I have had v2.xx.xxx with RMS in the past, but I try to keep everything on the current v3.x.xxx public-release version (once proven stable in a test environment).
    Roger McLean
    Swinburne University
