Lutron QS problems
cma
Thought I would try here as many of us also program lighting systems as well.
Anyone out there doing QS? I am in the process of getting one up and running. I can connect to the processor and "activate" it but when I go to activate devices or load the program I get an error saying the processor cannot be found. I can also connect using the QS IP Config tool and can verify that all network settings on processor are correct.
Lutron tech support has been of no help, they say it is my computer.. I have all antivirus turned off and am connected directly to the processor. Have tried through a router/switch as well as directly to the processor.
Any other things to look at?
Yeah that setting is bogus. I had the same issue and when I asked tech support what that setting was, they just told me not to touch it.
Unrelated, but I've had issues with activation seeing the main processors via WiFi on some jobs. I could ping the processor and log into the web interface, but the activation process wouldn't see it. Plug in Ethernet and it works....still haven't figured that one out, and activating a house full of dimmers sure is a pain when you're tethered to the rack. Tried a Windows 7 PC and my MacBook with fusion and win7 and got the same results.
Sent from my MB865 using Tapatalk 2
I had the same problem. Try to turn off windows firewall. That was helpful to me...
Definitely not a firewall issue. It works at some sites and not at others, and firewalls are always disabled.
Long story short: use a wired connection with firewall completely off.
