MVP-9000i lockup after sending a TPD4 file
dspot
I am in a project with 3 MVP-9000i. one of them locks up after sending a TPD4 file. The backlight is on, the blue LED is on (not blinking), but it doesn't respond to anything right now. I guess i can leave it until the battery's up and plug it to a power source. Can't say why though.
Another issue is probably related to the wired/wireless switching. Another panel was tested fine, and I put it in the docking station. This morning when I came to site, it doesn't respond to anything. Even the undock button doesn't respond. I think I could let it consume the battery too. Which brings me to another question. Is there a way to force reboot an MVP-9000i?
You can get to the setup and calibration and reboot on a 9000 just like an 8400 I believe, hold the bottom of the two touch pad areas until it does each of those in sequence. But if the panel isn't responsive, that won't work.
Interestingly, one panel shows the correct date and time, which I assume it gets from a connection to the master. But the master (looking at it from NS) doesn't seem to connect to it. So, right now all I have to do is to let the battery drain, or do I have another choice?
Another panel is still live connected, with the more or less same TPD4 file.
The reboot button near the stylus cavity will do it.
never noticed that there's a reboot button. shame on me.
The latest MVP-9000i firmware (v. 2.86.31, 2012-06-05) sounds like it addresses issues you are describing:
Took me a while to realise there was one too. I'm pleased they included one because with the initial firmware releases they needed to be rebooted a lot.
Now that I know it's not just me going crazy, I'll look further at it, and try to get a better idea when it happens. But it is definitely more likely right after a load.
In the release notes for that firmware under "PROGRAMMING INFORMATION" it notes:
Perhaps the issue you're seeing is due to the panel finding a "better" access point/band/channel and temporarily halting while re-connecting.
Not likely when it happens when I'm using the wired connection. There is also only one WAP in the house. Though that does bring up another issue with the panel ... fairly often, when switching from wireless to wired or vice versa, it loses the connection altogether.
That's been an ongoing problem although i thought an earlier firmware was supposed to fix that. As suggested in another thread i just disabled the wired settings and just use the wire for power not network.
http://www.amxforums.com/showthread.php?8031-9000i-autoswitch-from-wired-to-wireless&highlight=9000
That's a great idea. I'd rather have a slightly slower connection than an unreliable one.
