AMX Video Chat
Has anybody tested this module yet? I am working now with a MXD-2000XL-PANi and a MXD-1000i both on firmware 2.103.52 and a NI-4100 with firmware 4.1.373. I loaded the AMX provided module that you can find on the Modero X product page as it is and the code/module doesn't work. I noticed in the module that the models I have weren't implemented. I added the models above and still it doesn't work. I have a project with 9 Modero X panels and 4 iPads and client is inquiring about Video chat and Intercoming. Any suggestions?
Also the camera on the 20" panel I am working is not responding. The camera on the 10" works... To test the camera in your panel go to the Panel Setup, select Panel Configuration and make sure the Camera is Enabled. You may need to scrool down to see it. Then go to Configuration, Advanced and enter the URL: can://local.
It looks like AMX may have released this module without much testing...
